With all the massive power being made, I think it's time for a 500+kw(wheels) to see what has been tried and tested, and to compare combinations, similar to the 400kw thread.
List as much of your mods as you wish as the more info the better: engine, turbo,cams, boost etc etc
I will start:
RB26 stock block
Apexi SPL V-Max 73.7mm billet crank
Apexi SPL V-Max rods
HKS Step 3 87mm with 22mm pins
Apexi SPL V-Max 290 11.5mm cams
Apexi SPL V-Max Springs, retainers & lifters
Supertech +1mm valves
9.0:1 CR
HKS twin GT3240 + twin gates turbo kit
Trust sump (modified)
External single stage Moroso oil pump (wet)
Apexi SPL V-Max Drag intercooler (150mm)
3" dumps > single 85mm exhaust
Microtech LT12S
3 x 044's + large surge tank
6 x Bosch Indy Blues
Caltex E85
520rwkw on 22psi on a very safe tune, no cam timing, and low rev limit.
Plenty more in it with more tuning, boost, revs and cam timing, but this will do for now.
https://www.sau.com.au/forums/topic/411489-500kw-club/
RB30/25DET
NITTO/JE pistons 22mm pins
NITTO I beam rods
NITTO 1.2mm Drag headgasket
ARP Main studs
ARP Head studs
Nismo Engine mounts
9.5L ASR sump
Moroso external oil pump
ROSS Harmonic balancer with pump drive kit
Ported head
HKS 256/264 cams
Greddy Plenum
Q45 throttle body
Speedfab Exhaust manifold
Twin TIAL 36mm Wastegates
HKS T51R KAI turbo
4inch Custom turbo back exhaust
100mm Intercooler
52mm Alloy rad
SPAL 16inch thermo
2000cc ID/Bosch Injectors
SX Fuel reg
Twin entry fuel rail
2x Bosch 044 Fuel pumps
Nismo Intank Fuel pump
3L Surge tank.
E85 Fuel
Standard RB25DET gearbox
JB Single plate Full Monty clutch
Tomei Trax 2 way LSD
Supporting mods etc etc etc
547rwkw@25psi
Trapped 137mph on a practise run then blew the diff. :(
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6577905
Dave's list in black!!!
RB30/25DET
NITTO I beam rods
ARP Main studs
ARP Head studs
Nismo Engine mounts
9.5L ASR sump
Ported head
HKS 256/264 cams
Greddy Plenum
Q45 throttle body
HKS T51R KAI turbo
100mm Intercooler
52mm Alloy rad[/font][/color]
SPAL 16inch thermo
SX Fuel reg
3L Surge tank
E85 Fuel
547rwkw@25psi
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6578235
Full boost at around 6,300. Only revving it to 8,750 for now. will lift it to 10K when it is re-tuned later.
Traction? What traction? :D I have only driven it in RWD as my attesa isn't working and on stock wheels and tyres.
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6579526
Power was still increasing at 8750 and on previous tunes (with smaller turbos) power keeps rising steadily to 10K. We have found that rwhp output for HKS turbos can match the HKS rated figures of their turbos. The GT3240's are rated at 580hp each (@1.4 bar). On an RB26 in twin form, they need to be pushed hard (around 2.5 bar) to get over 1000rwhp.
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6580969
The 3240 is basically a 3540 with a cutback rear wheel, fitted into a GT30/28 rear housing (0.87).
With E85 and an RB30 I am not surprised you're making 750+hp @ 1.7bar with a large HKS single. I would love to swap to 0.73 rears or even 0.61's as the 3240's only come in 0.87
My tuna thinks that 2.5 bar is what it will need to get to 1000.
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6580977
  • 1 month later...
Hi everyone,
About time we posted this up - here are the specs on our "NITTO" R34 GT-R:
STANDARD RB26DETT bottom end
ARP headstuds
Nitto Headgasket
Standard oil pump
Custom head by Mercury Motorsport
6Boost mani
Precision 7675BB turbo
Twin Precision wastegates
4" exhaust custom made
Haltech Platinum Pro ECU etc.
Upgraded fuel system
Splitfire coils
100mm thick FMIC
Custom i/c piping
OS Giken sequential gearbox
Power: 622awkw/845awhp @ 43psi (ran in 5th gear, to keep the 1:1 ratio due to gear changes, 6 straps holding it down)
Here is the vid:
https://www.sau.com.au/forums/topic/411489-500kw-club/#findComment-6649687
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
