The T62R weighs nothing compared to a similar turbo from garret. That's why HKS charged the arse out of them when they went of sale. Its 8kgs lighter than the T88-38GK we were originally gonna run.
That is weight, not size. Always thought (still can't see any reason not to think really) that buying a GT4508R with a TiAL SS VBand turbine housing would be basically the same thing?! Changing that housing from the filthy big industrial thing that comes from Garrett is meant to reduce the overall turbo weight by about 33pc apparently.
T88 is a totally different turbo from a totally different manufacturer, glad you didn't go there!
Yeah i'm really glad we never ran with the T88-38GK, the T62R is an awesome turbo still have not found the limit on it yet so looking forward to when it finally peaks out at.
I read that the Tial SS housing were considerably lighter as well, i was going to run there rear housing on my SR20 when i decide what turbo I am running, my exhaust manifold has the 3 Tial V-Band on it. Those big monster Garrets require a massive beefy manifolds to support them other wise the start cracking the old stainless one e.g Trust manifold I am currently running.
  • 3 weeks later...
Got a video text of its run last night
Thing sounded and looked insane
Haha yer your welcome mani lol, but yer saw these runs at willowbank things an animal set off car alarms as it hit the two step in the car park lol
  • 4 months later...
Time for a new member.
-Twin 6258 EFR's
-Tomei 2.8lt Stroker kit with Custom 87mm JE pistons
-Advan Performance Ported Race Head
-Jun 264 x 10.5m Cams
-Full Tomei Valvetrain
-Hypertune Plenum 6 x ITB
-Plazmaman 100mm Intercooler
-Full Race Manifolds
-ID2000cc Injectors
-Motec M600 ECU
-M & W CDI Ignition with Weapon X CDI Coils
-3 x Bosch 044 fuel pumps
-Peterson 4 stage Dry Sump Setup
-4 Inch Exhaust
-OS Giken Triple Plate Clutch
-Holinger 6spd Sequential with Ignition Cut
-Tuned by Phil Armour Motorsport
  • Like 2
You're not taking into consideration the weight of the 6-pot caliper/355mm rotor fronts & 4-pot caliper/320mm rotor rears! ;)
R32 GTRs are A LOT lighter than R34 GTRs... We are unable to run smaller than 20" rims on NITTO due to the massive brakes. We cannot put 20" semis on it either as they simply won't clear the rear guards (not keen on damaging the House of Kolor paint!)
Ive got 380mm alcons sitting behind 18" ame tm02s?
And i just found out my 375 x 36mm alcon rotors on le mans daytona prototype monoblock billet alcon 6pots sit behind 17" TE37's.
355s with 20" rims, you should be able to fit a small child between the caliper and rim.
its another excuse to why it didnt perform after all the hype that they put on it
With all the massive power being made, I think it's time for a 500+kw(wheels) to see what has been tried and tested, and to compare combinations, similar to the 400kw thread.
List as much of your mods as you wish as the more info the better: engine, turbo,cams, boost etc etc
I will start:
RB26 stock block
Apexi SPL V-Max 73.7mm billet crank
Apexi SPL V-Max rods
HKS Step 3 87mm with 22mm pins
Apexi SPL V-Max 290 11.5mm cams
Apexi SPL V-Max Springs, retainers & lifters
Supertech +1mm valves
9.0:1 CR
HKS twin GT3240 + twin gates turbo kit
Trust sump (modified)
External single stage Moroso oil pump (wet)
Apexi SPL V-Max Drag intercooler (150mm)
3" dumps > single 85mm exhaust
Microtech LT12S
3 x 044's + large surge tank
6 x Bosch Indy Blues
Caltex E85
520rwkw on 22psi on a very safe tune, no cam timing, and low rev limit.
Plenty more in it with more tuning, boost, revs and cam timing, but this will do for now.
any more updates on this setup
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
