simon you still running standard valve springs?
suprised your not getting valve float on that boost and with bigger cams
As far as I'm aware they are standard, the Japs put the Grex cams in back in the day and they are only 9.1mm so only babies in terms of lift. Have never thought to check valve springs but I highly doubt it, they didn't even put aftermarket head studs in, just wacked the cams and head gasket in.
I was more worried about head float after the standard head bolts stretched :)
Me like-y, very much. R33 bottom end or R32?
Same motor that came with the car in 1991 (R32) but it's a very low km example... Done 46,000kms
Edited by SimonR32
  • 4 weeks later...
Pretty much same setup as the 8.97sec pass as before a few changes likenew fuel system and Upgraded head components have also switched to Methanol Fuel. Also dropped 140KG out of car now weighs 1280KG. We are currently running estimate 850-900 KW at the wheels.
Best ET is a 8.39 Seconds at 164MPH with a slow 1.3sec 60FT on Mickey Thompson Street Radials, currently makes us the Worlds Fastest street Radial Tyre RB Powered GTR, and also the Worlds Fastest H-Pattern Radial Tyre GTR. Only cars left to beat is the AMS R35 GTR which done a 8.28sec on Radials and 7.98Sec on slicks. Both those time are achievable with our current setup. The car is still not setup a 100% with its new systems a bit more fine tuning.
-HKS T62R Turbo
-Jun 2.7lt Stroker kit with Custom 86mm CP Pistons. Godzilla Spec Engine.
-Godzilla Motorsport Race Head
-Custom Godzilla Camshafts (Top-secret Classified Info)
-Full Supertech Valvetrain
-Hypertune Plenum with 4" Throttle Body
-ARE 150mm Intercooler
-Trust Exhaust Manifold with 50mm Wastegate
-Moran 5000cc Injectors
-Vipec V88
-M & W CDI Ignition with Weapon X CDI Coils
- Aeromotive Mechanical Fuel Pump
-Peterson 4 stage Dry Sump Setup
-4 Inch Custom Titanium Side Pipe
-NPC Twin Plate Clutch
-PPG 5 Speed Dogbox with Ignition Cut.
+ a lot more
http://www.youtube.com/watch?v=KNLs_gONSQ8#t=1
  • Like 2
-HKS T62R Turbo
-Vipec V88
+ a lot more
if you dont mind, what are you using to cut ignition on changes?
if gearknob, what brand, or do you have name of supplier?
cam pm if you want.
thanks, luke.
  • 2 years later...
Joined the 500Kw+ club today with the V3 prototype of my engine. This was the power goal that I had hoped for, as it is designed to be a torque monster with the maximum possible low end performance.
The tune is on E85 (75% content after the 98 octane tune), and was done in Cairns in 33 degree heat at 82% humidity.
Open Deck Engines 3.4lt (3360cc) Block (Rb26 24U based block)
Tomei Spec 2 head, Step 2 cams.
Precision 6466CEA 1.0
Full Race manifold with twin tial gates.
4" turbo back, 90mm Trust TI-R titanium exhaust
Greddy intake plenum
Nismo Intercooler
NPC twin plate
Haltech with IO expander, doing fuel pump and auxillary cooling system control
PWR 55mm twin pass radiator and custom oil-water heat exchanger, plus auxillary rear mount radiator and remote coolant pump.
Ignition project plazma coils
Completely enclosed crankcase breather system, designed to pull the engine into a vacuum under boost.
  • Like 1
Vented back to between the air filter and turbo and running a exhaust vacuum source with check valve?
No check valve, and no exhaust vacuum interaction. Pulls vacuum from the sump and head via a baffle system, to a ventrui on the intake between the turbo and filter. Any oil that enters the system returns to sump like a nismo setup, but at an elevated temperature to boil out any water vapor.
  • Like 1
Have you measured how much Vacuum your pulling in the sump, or are you just managing to pull blowby?
We were preparing to hand make a venturi between the turbo and filter, a few people suggested i look into the exhaust scavenging setups but my thoughts were that it may not work as well on a turbo setup as it does for the V8 guys.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
