So basically just acted as a vent to help oil drain quicker through the oil returns
Any more updates on the gtr ?
Getting a Quaife ATB front diff installed and the rear is getting rebuilt to around 30% higher torque settings. That plus the brakes and I'll take it back out for some fun :)
who needs dedicated track car hey ! nice man taking this to its full potential
what times did you run in the old green beast ? i need something to aim for once i learn how to drive straight :unsure:
66.7 I think was best long track, did some suspension stuff after that which would have made it quicker but never got it out again.
I think most the RWD quick Skylines are around the 66 mark but Denver is doing 63 (but that is a race car)
If you can crack into the 65's or better your doing well
  • 3 weeks later...
I've followed your build threads, gtst and now gtr, and ultimatey which 32 do you find quicker?
I thought you were nearing a 65 in the t67 rb25 rwd monster
GTR is miles quicker at the track and a fair whack quicker in a straight line, the old green thing was bargain performance where the GTR isn't
Well GTR ownership is getting expensively depressing. Quaife ATB which has finally arrived this week and is being installed on the 6th of Jan.
received_10153433527489616_zpswv1khlf7.j
Rear diff has been rebuilt and tightened so it's gone from 19lb/ft of breakaway to 49lb/ft. Should be even better for 4wd sideways action once both diffs are back in.
All shiny and tight!
received_10153433524284616_zpscfxayuws.j
Dog also helped me out to check out condition of the motor
Said it was all good!
Spare boxes for days, I've actually got 2 more but I wasn't moving them just for a photo :)
  • Like 4
  • 2 months later...
Went to my first ever event in the WA Sprint Championship, was a bit tighter and different to what I'm used to but I did really well coming in 2nd out of 83 cars. Got pipped by around half a second by another 32R which is really set up well with a RB30, EFR8374 and some very nice suspension goodies. About 4 sec clear of the rest of the field made me fairly happy!
  • Like 1
Finally back and running, the alignment got a bit stuffed up and they put toe out on the rear instead of in which made it interesting with delaminating tyres on the rear :)
This track you are on . Is it near Perth airport ?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
