Hey guys,
I've tried searching but couldnt really find much.
Currently making 347 rwkw
hks2540's i think - full boost of 22psi at around 5500 ish
powerfc
tomei adj gears
bosch 044
ported manifolds
hks dumps
hi-flow cat
z32 afms
sard 800's
Running standard internals
NOW to my question... How can i increase turbo response? Cams? What cams would be suitable Im hoping something along the lines of drop in i.e. keeping everything else stock.
I want a reliable driver also - and im 100% sure this car wont see a track day or drag strip plus i have shift light set at 7000rpms.
Lag is starting to annoy me and i really don't know what to do.. i cant afford to take out the turbos and buy and sell -9's or -5's.. What can i do to make the lag a little bit better/bearable?
Please don't flame, I'm asking a genuine question.
Thanks all
Edited by kinggtr
If you don't want to change your turbos then its just a matter of tuning to get as near as possible to the result you want. I would guess cams should stay stock but timing would need adjusting via the two adjustable gears (that's what they're for!)
Seems like you are in the same town as Status tuning so give them a ring and make an apointment - be prepared to spend around $1000 more or less for a decent tune.
I know you said you don't really want to change turbo's, but those 2540's are probably the worst lowmount setup on a GTR for any type of "'response". Cam timing and tunes are only gonna help so much.
A set of type R Poncams if you must buy a set of bumpsticks would be the go.
And make sure your exhaust doesn't have "step downs" that'll cause unnecessary back pressure
Turbos that size and an engine only revving to 7000rpm would be a dog to drive...
As already mentioned, well aware that you said a turbo change is not what you are wanting to look at doing - but at the end of the day the cams aren't going to be a budget mod and are really going to make so little difference you're going to wonder why you bothered imho, and will eventually have to do something drastic to polish the turd that is GT2540s (if you don't just replace them).
Honestly the most logical thing to do is change the turbos, as funnily enough anything else you do is not going to change that they are GT2540s and as such are going to behave like them.
Can I ask if you can't afford to spend the time removing the turbos or is it just a matter of money?
If it's just money i'm sure you can make a decent bit of cash back selling those and buying second hand -9s/-5s.
But yeah otherwise, who tuned the car and got a dyno graph of it currently? And have the adjustable cams been used to lower the power range?
Edit: What front pipes and cat back are you running?
Edited by Serpandrew
I'm not an RB26/GTR person but I'd look at it like this .
HKS effectively replaced the old "GT2540s" , which in todays speak are actually GT2876Rs , with turbos called GTRSs which are a GT2871R in 52 compressor trim .
People here say that it takes a specific combination of parts and good tuning to make GTRSs work on an RB26 and they actually use smaller but more modern compressor wheels than the old 2540s .
You could try all kinds of ways to work around those turbos but at the end of the day they are not a well though out turbocharger and you can do better .
Simply too big a compressor for the turbines to drive and thats what makes them lazy .
I think the designed for the purpose GT2859R (GTSS) are the go because they make boost and torque in the rev/speed range you can use in a street GTR .
Pretty sure you'd still make 300+ Kw but you'd drag the power range down possibly 1000 revs if not more .
So your call , either GTSS or inaptly called GT2530s I think .
A .
-9's are SS' s
-5' are close enough to 2530's.
Spend the money and rip those turbos off mate. You're about to drop a bomb of money and really, you're not gonna get the result you're after.
what are your cam gears dialled in as?
You could "possibly" get them to spool a tad earlier if you advanced the intake cams and retarded the exhaust cams a tad. A few people have gotten their GTS-ts to spool a tad earlier by retarding the exhaust cam gear only.
Hey guys
Firstly thanks for all your input on this matter - ill upload the tune soon.
Not to sure what's been improved from the cam gears other then an obvious lift on all parts on the graph.
I swapped out the gfb manual Bc and swapped it over for an eboost street and don't a few adjust I'm getting a rushing boost feeling from 3000 rpms and full boost at 4800 5000
Could they be 2530s? I also noticed an intercooler pipe leaking which I sorted out.
Lastly I spoke to my tuner and he explained how opts for a smooth graph and smooth power delivery. Maybe im just used to the standard response of the ceramic turbs?
Peak torque is 3/4 up the powerband, no wonder your not happy..
Im really with the others and will say spend wisely and just get real turbos. To match the peak you will need -5s. Check serial numbers before you do anything, obviously..
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
