Got a bit of a start on the dump. Cut the taper to fit the v-band, ground it perfectly flat (one of the (multitude) of keys to a half decent tig weld I slowly discovered doing the rest of the exhaust...) then tacked them together. Measured up the first bend off the taper and cut the end off the 90 degree bend. Because of the front mount manifold it means the turbo is on an angle so you need to go down and away from the engine at the same time. Makes it a bit trickier...
I'll be cutting more off the end part way through the 90 but tacked it on and I'll work out where to cut it while it's in place.
20191011_212053.thumb.jpg.7c3bdb03fd2a031171b94c9ae73fbd65.jpg20191011_212038.thumb.jpg.65b2f472393c1b03d7215d0623910a30.jpg20191011_212249.thumb.jpg.0d92efaf4ea047f3ab2ed1514ce708ce.jpg
20191011_212301.thumb.jpg.b189a0e0a8818d53cd14e5e5194248ea.jpg20191011_220833.thumb.jpg.5e9b018e95abced6598338f20e1c4355.jpg20191011_230857.thumb.jpg.af1a1ea935465bdc2a62b0b8434686a6.jpg20191011_231020.thumb.jpg.8233c6a2584a2bc94f8f6a2c381dd20b.jpg20191011_231010.thumb.jpg.e2af02083b6eb1dd6c05c0046180f5fe.jpg
  • Like 2
Ha ha!! You’re persistent!
I currently have one point left on my licence so I’ll be looking for ways to be less obvious to inspector Po Po. I don’t think a bonnet exit exhaust and screamer will help me achieve my goals ??
  • Shoota_77 changed the title to Shoota's R33 GT-R RB30/26
Got a bit more done of the dump. Pretty much out the bottom now.
Has anyone come up with a solution for the a/c evapirator drain pipe? Ive gone closer to the firewall than standard. Might just chop most of it off and leave a little dick poking out.
Did my first full (not just tacking) weld on the dump pipe. Did a terrible job ?.  The rest of the exhaust I didn't use filler. With the dump I did so felt a bit uncomfortable. I get so bloody nervous and jumpy when im welding.  I need to chill out and slow the f down!! Once it's ceramic coated it won't be so obvious how nasty it is.
Slow going but good to be making some decent progress!
20191013_150351.thumb.jpg.628035b2604d3bab028ba3d55c04069f.jpg20191012_170836.thumb.jpg.aeddea2fb83d091e364dd472fced7b4a.jpg20191012_170842.thumb.jpg.664abed34b85ba18062c5e8a205c9589.jpg20191012_170831.thumb.jpg.4c2e6dc1738e479a015d7f3db4ab0cb5.jpg20191012_223013.thumb.jpg.ff88cdba70ee438130d704f424c10e68.jpg20191012_223019.thumb.jpg.7b57c5a8a785531d30494275ea9777df.jpg20191012_230423.thumb.jpg.71a88e411375f38a64fd47b65a18d08a.jpg20191012_230449.thumb.jpg.7c082093d07ee9a59d4286127bbee1de.jpg20191013_150351.thumb.jpg.628035b2604d3bab028ba3d55c04069f.jpg20191013_150503.thumb.jpg.c6892a1f1426c1c1822231f4deea3bab.jpg
The only restriction in mine is the dags from my cocky shit welds! ?
I'm a bit scared with how loud it will be with just a rear muffler. May have to put a resonator in it at some point.
Thanks mate. I probably put a bit too much pressure on myself for a bloke who learnt to TIG off YouTube!
The sense of satisfaction at the end of this bloody long winded exercise from having done everything myself on this car will quickly overcome my self disappointment over a few shoddy welds!
Just have to keep pushing while the motivation bus is in town!
I’m up in Sydney for 3 days at the moment so missing a few nights in the shed after work because of that.  Hopefully got a few full days at the end of the week to finish off the exhaust.
A few more bits and pieces done.
I seem to be 2 steps forward one step back. I keep adding and changing stuff as I go...
The dump pipe was getting too long to feed down through the engine bay so I've added an extra v band in to make removal easier.
  • Like 2
Got a few more sections of the exhaust done today.  The dump is almost connected to the cat which is he original part of the exhaust I made when it was still going to be twins.
Went and got a few sections of 3” stainless bead rolled to be used for the compressor side to intercooler and then on to the intake.
Had the compressor housing hose section machined off to allow fitment of a v band rather than a hose. Need to order in the 90 degree bend though as it’s some sort of weird v band size...
Got a start on the wastegate merge into the exhaust. Wow, that was a shit of a job cutting the pipe to fit the exhaust nicely. I just couldn’t get it perfect. With TIG you don’t get too many chances with crappy joins. Decided to just go with it and try to panel beat it into submission! God I wish I had a pipe notcher after that.....  Would have made it so much easier than all the cutting and grinding I did on it.  Took me  Hoooooouuuuurrrrrsssss!!  Started tigging it up using heaps of filler wire to bridge the shonky gaps!
Still a fair bit to do. Waiting on another flex joint (baffle style) as I wasn’t happy with the one I already had. It was way too big. It’s supposed to be 4” but the 4” tube was dick in a bucket. Way too big to be able to TIG. Even MIG would struggle to bridge the gap it was that far off.
  • Like 1
Pretty much finished off the wastegate merge. Man what a mission I made that into.... I reckon i put 5 or 6 hours into that section alone ?
Lucky I'm enjoying it! Such a sense of achievement each time I finish each section.
  • Like 1
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
