Hi guys,
I'm dreaming up a list of next mods once the weekender is sold. I've checked several threads like this and this but many of them seem quite dated - I'm looking for 2012 information.
The car is an R34 GTT with basic upgrades: FMIC, full 2.5" turbo back, high flow cat, TurboTech V2 manual boost controller and Nistune. It's currently pushing just shy of 200 rwkw.
I'd be aiming for a reliable 250-280 rwkw in the next stage, preferably without too much lag. I like the idea of a high flow as it bolts straight in. Is this power level possible with a high flow? Are there other companies besides GCG doing good high flows?
Besides high flow, what are the other options when staying low mount? Something like a HKS GT-RS?
Also I assume the basic supporting mods are a Z32 AFM, 040 fuel pump and injectors (what size?). What else is needed? Also I'd be retaining the Tiptronic auto, would it cope?
What kind of overall cost would I be looking at? I'm not keen on doing engine internals, cams, or running E85 etc.
Any feedback and recent experiences welcome.
Thanks
  • Replies 57
This is easy. Check the Hypergear thread. There's 338 pages right now. You need to read the first few, then the most recent few. Then check out Hypergear's site (links in the first post). There are a few options for hitting your desired power levels with high flows and bolton brand new turbos.
You're going to need at least 500cc injectors. Probably worth getting smoe ID1000s, which will work fine at your intended power level and also support E85/Eflex should you go down that path.
The auto will probably end up shitting itself. You could wait for it to do it then build a stronger one, or you could get it kitted straight away. I'd swap in a manual myself.
Turbo is <$1500. Probably cost you ~$500 to install it. Probably cost you ~$500 for the extra bits and pieces that woudl be smart (like a new steel/alloy turbo inlet instead of the sucky shutty rubber one). Injectors aren't too expensive. I'm not sure where they are cheapest right now. You need a tune, that's several hundred, plus the install of the pump and AFM. So you're in the ballpark of a few grand without considering the gearbag.
Oh, you need a 3" exhaust too. Don't know how you managed to get a 2.5" exhaust on it......it's not like they're common.
Two threads for you to check out mate, the RB25 Turbo Upgrade thread and the Hypergear thread. Both will tell you everything you need to know. Costs depend on what parts you end up going for, best to do a bit of reading first and then set yourself a budget.
for the injectors contact injectorsonline.com , i got my 1000cc ID's for $110each which is very reasonable, ive read on the forums a gt3076 can be had for $1200 from ATP in the usa, that would do the job nicely but not would need a custom dump pipe, probably need one anyway, you'll need atleast 3inch dump, the intake pipe isnt hard either could even do that yourself, buy a mandrel bent pipe from exhaust shope and some silicon hoses..
Gt3076r will certainly make 280kw+, but the op doesn't look like he would want to go down that road due to being slightly more complicated to put in due to needing a new dump and turbo lines.
And the gt3076r's that do bolt up to the Nissan standard dump are average at best.
Edited by Mitcho_7
for the injectors contact injectorsonline.com , i got my 1000cc ID's for $110each which is very reasonable, ive read on the forums a gt3076 can be had for $1200 from ATP in the usa.
I got my gt3076 from ATP and it certainly wasn't that cheap.
Id1000s are a tight squeeze under the stock plenum (it's doable though) and do you need a new rail for the 34's or not?
I reckon a Hypergear ss2 is the go for sure!
From what I've read I believe that 280kw would be out of the question with 250-260 being the max for the output on a 34 hi flowed turbo. There's some very helpful info in the Hypergear thread, and Stao is great to talk too. Very helpful and knowledgeable. I'd suggest looking at the SS1PU (good for a street driven car, responsive and good for around 260kw) or the SS2 (externally gated, 280 is attainable).
Not to sure about the auto, but I'd imagine it would start to slip at these power levels. Once again I'd suggest having a read through the automatic performance thread.
how much was yours then cause i was considering getting one from them... i got the 1000's in my 33 with a cheap topfeed rail so should be no problem with the 34..
dont the hypergear's need alot of boost, most graphs i see use over 20psi , so not great for the auto box..
Hypergear test car ran an SS2 at 22 PSI (?) from memory. Doubt the auto would handle that at all. OP would require some serious work I'd imagine for the auto to handle that, plus I'd say you'd be playing roulette on stock internals running that as a daily?
Edited by gtsttrk
Awesome thanks for the responses guys! Back to my homework then.
Oh yeah and the exhaust is 3" with a 3.5" section between the mufflers ... I must've been thinking of the twin 2.5" on the Monaro, do'h.
Hypergear uses the test car to show maximum turbo capacity, those results are probably of when they stops making power. I'm making 261rwkws close to stock response out of their ss1pu turbo on 17psi of boost. Give Stao a ring and pay him a visit, he can high flow your stockie or customize some thing for your needs.
my op6 high flow made 248kw on 18psi and i think generally a standard highflow in most cases wont fit the bill.
Seriously consider and ss2. Even internally gated it should easily make 250kw+ on an auto, then get scotty to knock you up an intake, throw on a z32 and some injectors and you'll be set.
The SS2 in .63 rear or a SS2 OP6 high flow seems to be working well with auto trans. This is my very first SS2, it was sold to an auto owner and tuned last year. The car made a responsive 259rwkws peeking 18psi of boost. I'm not sure if the transmission has been worked. R34's select speed auto has pretty long gear ratios, setups felt abit laggy on a manual is pretty laggy on the auto. The SS2 in .63 / OP6 highflow or the SS1PU is probably the top choice for a internal gate bolton for your goal.
I will be around through out xmas period, come pass for abit of test drive or have chat when you free.
SS2 .63 Auto, Pump 98
How on Earth does boost pressure have anything to do with the transmission?
I was going to ask this as well.
Maybe if the turbo kicked in to fast it can make the gears slip or something but that has nothing to do with boost it has to do with turbo choice
Yeah I worded this very very poorly. What I was tryig to say (poorly) was that I didn't think that the stock auto would be able to handle the power levels (ie. 280ish kw), but yeah I worded it very poorly.
Reference to the boost levels was in response to the poster commenting on the boost that the hypergear turbos ran in the test.
But yeah reading over it I can see how it's caused confusion!
Maybe the right word instead of boost should of been "Torque", which is different for different turbo's with varying boost, on the same turbo though more boost will strain the clutches and they'll slip, also how much the auto slips the gears in compared to just dropping them in more, maybe if the solenoids could be adjusted to drop gears in more and less slipping would be a good thing to do.. My first skyline r31 auto was running 14psi which i didnt know until the gears started slipping badly, so more boost in that instance meant failure, dont know how much better the rb25 box is..
Edited by SliverS2
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
