It is clearly a nice example however I'm surprised how much the centre console gauge needles are faded. Unless the car lived a lot of its life outdoors hence Sun fade.
I know it's a small detail but it is a tell tale sign of how the car lived it's life, call me crazy but these are things I look at, amongst other wear items like foot pedals etc
Hi Guys,
I have a new addition to the register. It's a 1994 Vspec 2, auction grade 4, imported through Ben of J-Spec Imports.
  • Model of car - V-Spec II
  • Build date - need help with that :)
  • 'Chassis No' code - BNR32 - 313373
  • 'Model' code - KBNR32RBFS8 AA
  • Photo of the blue chassis plate (Will have it uploaded soon)
  • Where the car is located - Sydney!
Car is scheduled to arrive Australia in November, so hopefully it'd be on the road soon after that. Can't wait!
A few photos to start with,
  • Like 1
Make sure you send me and Terry a PM once it's complied and we can catch up for a coffee.
You don't often see 3 V-Spec 2's side by side.
Any other V-Spec Sydney owners would be most welcome too.
Bob.
Hi Guys,
Build Date = October, 1994.
Looks clean for its age :)
Thanks. AFAIK it's a pretty standard vspec 2 but I do hope to be surprised and find a Nismo built N1 engine under there. :)
Got the Auction Sheet / Dealer Car Info?
  • Like 1
Bob.
Yes definitely Bob. I'm actually going to pick up a N1 bumper from Terry this weekend. Would be nice to meet a few more Vspec owners eventually.
Thanks for the build date. Yes got the auction sheet here. Will upload it later tonight.
  • Like 1
I've been thinking about putting into storage the original wheels, radio and even steering wheel as soon as car lands. :)
Cheers from one OCT 94 to another.
I took the steering wheel off (replaced by a demountable Momo with a quick release and lock cover - strictly speaking not legal but excellent theft protection) I am also in the process of organising a replacement gear knob and handbrake cover and longer term looking at a replacement drivers seat and/or seat cover.
This will allow me to put most of the original 'wearable' items into storage and will give me the ability to return my car to 'fully stock' if I ever sell (have even kept the little brass boost restrictor which was removed ;-)
I am keeping the wheels on as I like them and have no intention of changing them for other rims but am even considering getting a spare rim as 'insurance' for a nasty scrape or similar......
Anyhow - have fun with it - the waiting is the hardest part ;-)
Cheers
The stock Baron
I found excellent+ stock mats (really, really hard to find) and put them in storage... and installed black Nismo ones.
Other than that I'm slowly procuring new mouldings and rubbers for the exterior and I'll have a respray done at some stage - two dogs tried to get in the driver's side window once and scratched crap out of the door and adjoining panels, then I had two 'bumper corner scrapes' in carparks :wacko:
Something interesting that I was discussing with someone yesterday - mine had about 65,000km on it two years ago but hadn't been driven much. It had had all of it's scheduled services, but only very occasionally driven. Now it has 95,000km on the clock and with thorough and diligent maintenance along the way it is driving better now (engine and drivetrain) than it did when I bought it. It actually keeps getting better. Love it.
I don't mind putting km's on - after waiting for 20 years I have no intention of ever selling my 'hero car' and I thoroughly enjoy driving it. It's certainly the coolest car on the school run most days.
This !!!
My daughter loves a ride in the GTR ;-)
Cheers
The school Baron
Cheers
The stock Baron
Thanks for the ideas Baron. Will have a closer look at the wearable items when the car is here. I hope the original seats under the leather covers are in top condition, in which case, they would go to storage as well. Maybe replace with R34GTR seats or some JDM items?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
