hey guys, recently imported my 32gtr.. im posting here because you guys seem to be pretty knowledgeable on this topic. Could any of you identify this sticker? is it a next service sticker?
thanks
  • 3 weeks later...
If any of you guys are thinking of possibly selling a vspec 32 gtr please drop me a message I may be interested
An an N1 would be nice but no doubt out of my price range haha
  • Like 1
Gho5t, thanks for that link, I was following it on yahoo auction.
Can anyone put me in contact with someone that has an N1 with the factory non-AC equipment still installed?
thanks
Post a larger and more clear pic...
But from what I think, it's either timing belt or gearbox oil...
I know someone that has a non AC equip R32 N1. What is it that you would like to know? PM me.
Going to look at a KH2 (Gunmetal)1993 V spec this afternoon
It's got an R33 engine apparently but comes with the original engine...
Looks mostly original beside wheels but I think the original wheels come with it
120,000 odd kms
120,000 odd kms
3 of a kind?
  • Like 1
Ha not yet Anthony!
Bob, it did not go well. Car had been resprayed, in totally the wrong colour! The body was straight but it would need to be painted again, properly.
Overall in pretty poor condition and would of required waaay to much work to get back to a state I'd be remotely happy with.
Let me know if you guys come across any V specs or V spec II
But I am thinking it be the case of buying from Japan...
Did the V spec II come in KH2 colour??
Firstly, yes...... KH2 was available in V-Spec 2.
They do command a premium but like most R32's finding a good one takes time.
I'm just spending an insane amount of money on mine to get it right.
I'm past the point of no return and just couldn't be bothered starting all over again finding another. I know how hard it is.
I'll post up pics once completed, hopefully this week but in a nutshell, all rust areas will be repaired including the driver side rear quarter panel and sill etc.
The entire RHS will be painted as is the front bar.
Money pit but nearly there!
Bob.
Bob.
out of curiosity Bob who is repairing / restoring your car?
My guy who I have been using for 7 years recently picked up AAMI and has become a preferred repairer and simply can't do private work at the moment.
I then asked around and was recommended a BMW preferred repairer who's credentials are excellent.
Unfortunately he is a fair bit dearer than my previous guy but I think will do a better job.
I've always struggled withmy previous guy's colour matching........... But as the old cliche goes, you get what you pay for.
Once I collect the car, I'll post up his details if I think he deserves it.
Bob.
Bob.
please do. Am keen to see the results
I think it's good value and if I was in the market I'd probably jump on it.
The only thing is to make sure it's a genuine V-Spec 2.
It doesn't take much to add wheels and Brembo brakes.
The spare wheel is yellow and I always thought the V-Specs got the larger black space saver to fit over the bigger brakes, I know mine has.
Yet, both my ADM's have the smaller yellow spares.
The blue ID plate on the fire wall will confirm its legitimacy.
Cheers,
Bob.
  • Like 1
Bob.
Hi Guys.......... Here are some progress pics............
Bob.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
