cool build, great to see some nicely built 25GTt's.
definitely invest in some good tyres, coilovers and arms/bushes,will make a bigger difference to laptimes than a bit more power (though obviously you want to sort the restriction out first..)
ive got cusco arms, great build quality and got a perfect alignment with them, car feels great on the track.http://www.cusco.co.jp/en/catalog/pdf_catalogue_suspension_parts.html
nagisa auto also do a bunch of arms for R34 25GTt http://www.nagisa-auto.com/products.html
i'd order throught jessestreeter, should be able to get the stuff for a reasonable price for made-in-japan quality. my 2c.
Cheers :thumbsup:
New suspension setup & a 1.5way diff are definitely on the cards next!
I have some Hankook RS-3 ready to go on which should be good
Cheers for links! It will be helpful once I shop around for parts :)
mate great build going on there. i have had a lot of the same sort of modding ideas as you have done already.. good to see that all of it is working out for you which helps me out a lot also.
great inspiration mate good up the great work
Thanks Jake
Yeah its all slowly starting to come together
Theres still quite a long list of things that I still want to do. It really never stops :/
Quick update:
Just got a few pics from Vu @ DT Panels. Shell is going in for paint tonight, and then assembly tomorrow
1472955_10152052600385937_1296586892_n.j
1459245_10152052600645937_1309428566_n.j
1454960_10152052600770937_1023195141_n.j
1466095_10152052600820937_884529813_n.jp
1441228_10152052600880937_1195689344_n.j
On 12/4/2013 at 5:14 PM, Miguelone said:
What colour did you end up going with?
Ended up going the dark metallic grey from a Subaru Brz.
Additional pics I took today
Hard to tell on the camera, will look at lot better once out in the sunlight:
Base Coat:
Final coat:
1398139-764969923517369-1390868036-o-764
1400460-764969916850703-2136217733-o-764
1402900-764969843517377-96613856-o-76496
thats a really nice colour.
+1 to endless list of things to do on car. But then again, if you ran out it would be less exciting and interesting
Ahh Leroy you and I know that feel
Also
Live updates from Vu @ DT Panels. Great service :D
1471105_10152054579075937_835909422_n.jp
DT Panels had to custom cut the side skirts from the kit as they were made to fit the GTT guards from the old kit. Final result! Good result! and saves me time and money to find impossible GTR side skirts!
1453523_10152054587305937_818755292_n.jp
1468817_10152054603540937_1278311278_n.j
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
