Injectors tested this morning for flow:
Injector 3 partially blocked
10422451-1049642461716779-75584820019175
Injectors cleaned:
11079571-1049642321716793-75368241378760
Flow back to normal:
10613153-1049642295050129-75510092798671
Engine head being looked at:
11112218_1049642438383448_26285725279759
Lots of black goo inside
11072537-1048810498466642-52311380285712
11075297_1049642378383454_63030722592499
Put some of the goo in some 98 octane. it did start disolving, but not at any rapid rate:
11081349_1049642358383456_35028527027044
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
How'd you end up going with all this?
PS - your pics from earlier in the thread aren't working any longer! :(
Damn that sucks will take a while to relink lol
update?
car is running again and aiming for flex tune, as far as I know.
Get the car back this week
Tuned at Racepace
Initial runs on 19psi:
320rwkw on 98
355rwkw on e85
Was told by Luke if i fix up my cooler pipes, airbox and bump up the boost should be around the 420rwkw mark
Lower reading dyno then Trent's as nothing has been changed on the car. Made 385rwkw on Trents with a run in tune
  • Like 1
  • 1 month later...
So planning to get back into motorsport
Installed AFR gauge so my motor doesn't blow up again
14980771-1483524644995223-37133225899040
14980771_1483524644995223_37133225899040
Things do be done before Sandown next month:
Install front cusco camber arms and castor rods:
10806490_1021991554481870_50100739818297
Nismo 1.5 Way LSD diff. Ordered from Jesse Friday, arrived Monday. Great Service
14993554_1483524684995219_81965391974457
Whiteline front and rear sway bars to come
  • Like 3
52 minutes ago, admS15 said:
Nice part selection, very similar to what I'm running except for the Nismo 1.5 way. Much want. Have you decided on which sandown event yet?
Had a chat to Richo about this he reckons tampered is a better bet. Avg of about 60 cars i think.
Also they are running a special at the moment. $220 down to $200
37 minutes ago, V28VX37 said:
Holy moly that's some quick delivery from Japan, Jesse rocks!
My car is finally back together but I'm sure you'll learn what this diff is like on the street soon enough :)
With your recommendation! maybe see you at the track?
  • Like 1
48 minutes ago, admS15 said:
Yep, I was leaning that way. If the weather looks good, I'll be there.@V28VX37 are you in?
Darn would love to but it's better half's birthday weekend, not negotiable... What's the other event?
Rexmas is the week after.
Id consider it maybe if my car holds up 100% lol and i got no plans
  • Like 1
Yeah pretty keen on that. I need to do a proper test drive/mountain run before signing up though to build up confidence in the car ;)
On 11/15/2016 at 3:59 PM, Kinkstaah said:
A lot of those parts are very similar to my car Tony, I hope it serves you better :P
Well glad i didn't go standard manifold with an external gate welded on lol
Sway bars arrived:
15037149-1488580977822923-39243820255794
Work by JDM Garage, Suspension going in:
15036382-1488580954489592-39669808674051
15036230-1488580657822955-71032392549226
15032274-1488580931156261-22780175061665
Now i just need a wheel alignment and install the diff
14993554-1483524684995219-81965391974457
  • Like 3
Tony those mods look great! I wouldn't mind upgrading my two-part front camber arms to single-part items at some stage.
5 hours ago, admS15 said:
Good workemoji106.png just had a look at the supp regs for rexmas. Untimed event and only 80% of your usual speed allowed. That sounds gayyyy. Lol. I'm out for rexmas.
Yep I just saw the 80% rule too, sucks bad. Looks like there's a Maserati Club Come and Try on Dec 10, not a great date and not sure if you can run full pace there either: http://www.maserati.org.au/event-2372776
