Running a precision and came with a 3 5/8 flange, which tapers down to 3" around the cat. I wouldn't go any larger than the exit of the rear housing, counter intuitive.
I'd only use v-bands where you really need the seal to be tight, they look cool but can be a bitch to line up and get back on.
This is what I got made up for mine, have little pipes to run as screamers or can be fully plumb back
And u gotta use teflon pushlok hose for e85
Edited by n_D
Looking good man. You must have been pumped if all of the Aeroflow stuff arrived at once! I have been ticking really similar goals off on my build. Looks like its all coming together!
Yeah it's so much stuff when it is all laid out on the bench like that haha. Pretty stoked with the progress at the moment even if my wallet is not.
Nice work as always, but just a heads up, you might want to think about upgrading to a 3.5" exhaust.
Hey man thanks, this is honestly something i should have thought about earlier but it is too late now. Plenty of people have made over 400kw with 3" (and mine is completely straight through, no mufflers/cat/resonators at all!) so i don't think it will be a limitation. Plus im not shooting for power like that anyway!
Will be going 4inch dump on mine, then 3 1/2inch back to help it breath..
The rear housing adapter Tao provides only has a 3" outlet so i don't need anything ridiculous, besides, it's too late now anyway haha.
Exactly right, no point in having 3" dump (as that is my exhaust housing outlet size) and a 3.5" or larger exhaust. I found the V-Bands pretty easy to align and get on, that was with two people though. One person might be harder but how often do you take your exhaust off? And surely you can find one mate to give you a hand hahah.
butterfly in exhaust is one thing im seriously thinking about. My car is loud and dont think my neighbors like me when i come home late night.
Exactly the reason i want one! I try to be as reasonable as possible as i know i wouldn't appreciate it. Unfortunately due to time and money constraints this idea was ditched, but it is something i would like to try and incorporate in the future. Once the car is up and running i will get something sorted, i think it is a pretty good idea for a common problem.
I know haha, I took it off the car (which was literally a 5 minute job, thanks V-Bands) just to take photos of it! And now it's off I don't want to put it back on because it looks so damn sexy! It bolts to the gearbox as well for bracing. And it sits so flush up against the body it's amazing, can't even fit my fingers between the top of it and the floor pan, running nismo mounts so it should be fine.
Exhaust also comes with a lifetime warranty, and was VERY reasonably priced. The work Dann does it absolutely top shelf, and backed by a lifetime warranty. I highly recommend to anyone!
My old exhaust was a stainless/mild mix and a bit of a slap together job. Was never loud enough for me, but I think this should definitely be loud. Left room to put a muffler/resonator in later if I want :)
  • Like 2
Very nice mate, good to see it moving forward.
May i ask as Im about to get my intercooler piping done, whats the thinking behind having the BOV on the turbo side and not the intake side? Or does it not really matter? I was going to get mind on the intake side, just after the throttle body
Looks good mate, some ear plugs will be needed i reckon, will be interesting to see how well it flows, hope those black silicon hoses don't blow out under boost though. Looks very clean and well done though.
  • 1 month later...
Thanks guys. Was getting so sick of working on it after all these moths, had really lost motivation to do anything and was hating it.
Finally got it mostly sorted and had a quick squirt around the block today. Put a smile on my face for sure! Was nice to have the car in the shed and walk away feeling happy about it :)
Just a quick photo as I put it away.
  • Like 1
Don't know anything about BOV's sorry man as I have never run one. Before this I used a cefiro crossover pipe which had no BOV provision from factory. And I'm not using one now :)
  • 4 weeks later...
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
