aw man thats horrible at lest you got off easier then it could have been, those defects are easy fix's though right? slap on some stockies. make a cold air box (i have the stock box and snorkle i can send up to you if you want) and just jack up the coils?
best of luck with it mate!
Yea definitely could have been worse, just a pain in the ass. The defect notice requires a full inspection/blueslip to be cleared though, so it depends how much of a c*nt the local guys want to be. I just went and saw one guy during my lunch break (everyone has been recommending him to me as being the more leanient of the local guys) and he said make the exhaust quieter, stock wheels, stock air box (I still have my stock one luckily, but thanks for the offer :D ), and raise the back of the car up a little bit and it should be ok. He didn't really look at the car though so I'm a little skeptical he will change his mind tomorrow which I was luckily able to book the car in to be checked on.
Well, yesterday I raised the car suspension and had it realigned. All was good in the world. Until I decided to test the newly acquired launch control with semi's on haha. Now I'm on the hunt for replacement driveshafts. Better now then at the supersprint or hill climbs I've entered next month lol.
Anyway, for your personal entertainments, here is a video of bangs and flames.
Edited by timmy_89
Well I managed to source some second hand drive shafts from a fellow SAU member nice and cheap, and then it turned out I had a friend who would be driving within about 5kms of where the guy lived, so he picked them up for me the following day, which meant I had my replacement driveshafts before the weekend.
The process of changing the driveshaft over was actually easier then I thought it would be. Just unbolt the upper arms from the hub and the 5 bolts on the diff end and with a bit of maneuvering I was able to slide it out.
After bolting everything back up it was time to have a couple of beers and open up the boot on the old shaft. Whilst removing the from the car, it felt pretty obvious that the CV was shattered.
I figure it can be repaired with a bit of superglue right?
  • Like 2
Nice build mate. How much did the gear box shipping cost? I had a look at RHDJapan website and the box itself is around 1.6k aussie. Did they charge you much for shipping?
Cheers
Amir
Cheers.
At the time it cost me ~$1800 for the gearbox and ~$400 for shipping.
  • 1 month later...
So yesterday I entered myself into the supersprint at Mount Panorama held by the Bathurst Light Car Club, the first supersprint that had been ok'd by council in the last 3 years.
The day started out beautiful, but made a drastic change into a downpour of rain after only the first couple of runs which meant I really only got 1 sighting run and 1 "fast" lap of 52.47 seconds before the track was wet.
In the end they had to call the day short (still managed a few wet runs). Definitely something I'll be aiming to get to again to improve on times.
Vid of my last run in the wet, which as you can see was slippery as hell!!
EDIT: Second YouTube link not working so posting in next comment :)
Edited by timmy_89
  • Like 1
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
