Hey guys,
I bought a 1.5way ATS metal rear diff. Now, I'm thinking should I buy a front diff lsd as well ? Car is mostly street-driven but expect to make about 30-50 launch a year and maybe 5 track event ( never went lapping yet, so I'm a newb)
I searched and couldn't find much information really. Not enought to make a concensus, at least. What I found from GTR.UK is the front lsd is somewhat a bad idea and difference should be very marginal and very bad if used on the street. ( but this is mostly regarding 1.5way).
Here, only few peoples have spoken and most said, they were good when matched with other drivetrains mods. other only said quaife was better but not why or anything else..
So please tell me, what if I buy a cusco LSD and set it to 1way instead of 1.5way. would I see a gain or really 90%of the difference is located at the rear wheels ( and it has already been taken care) ? and how would my street driving be affected ?
I live in downtown and can be stuck in traffic from times to times so I always try to make it as street friendly as possible.
Thanks a lot!
https://www.sau.com.au/forums/topic/422006-front-cusco-lsd-on-gtr/
  • Replies 52
100% the quaife center.
There is no other choice for a GTR when I'm asked to fit one.
They aren't noisey and bang around
They transition nicely when power is applied
Drive is always consistent to the front axles
They just work and do everything in a nice way not a harsh slap happy way.
Quaife. Just do it and don't think about it.
You don't know it's there until you want it to be.
Exactly,
I to have the Quaife front LSD and I forget it's even there, brilliant for daily street driven GTRs that do occasional trackdays or drags
Exactly,
That's one thing I did notice with the few launches I have done with the quiafe in. It launches SO MUCH BETTER! Stupid standard diff crap!!!
Hi Paul - can you PM me as well please ... it's something I have been thinking about for a while
You won't be looking back... I sound like a broken record, but it's one of the best things I've done to the car.
Hey Paul
I am thinking of going this way on my R32GTR build. I recently purchased a quaiffe 6 speed dog box for the car(not fitted yet). I am thinking this Quaiffe front diff might be a nice compliment to the new engine and box I am adding. Do you have any other suggestions for the drive train?
Can you PM me the details of your dif supplier as well? Cheers.
Next time you are down Paul I'll have to take your car for a spin and see the difference between your Quaife and what my Nismo front LSD was like, as my Nismo was exactly the same as this one it settled in (about 500kms)
NP man. I think we are coming down for the next DECA. Hopefully you can make it :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
