So initial word back from GCG is that the core needs to be replaced in the HKS, housing seems to be ok
We'll get a phone call sometime this week to go pick it up
In the mean time, we went a bit crazy on a recent order with HiOctane for the 34......
So we have got:
Haltech ECU
Tomei Type-B Pon Cams
Tomei Cam Gears
Walbro in-tank fuel pump
850cc injectors and FPR
Upgrades gears for the oil pump
All this will go in after the track day in September, I want to get used to the new clutch first before putting more power in the car
We'll also be putting in a Gates timing belt and a new water pump while we are in there.
Also planing to get a Plazmaman plenum, throttle body and Billet fuel rail, paint the rocker covers and clean up the bay a bit
BRB while I start on my Mi Goreng diet lol
  • Like 3
I'm not too fussed on the wait for the extra power but my mates and mechanic have been pushing me to do the work now and not wait until after track day.
I could do it all now and it might be ready by track day (all depends on my tuner) but I will probably miss the 32 GTR 25th anniversary day cruise/lunch next month which I really want to take the 34 to
Having no boost for a month is a killer lol, it's an addiction. The longest I've gone without the car previously has been 2 weeks so this is a real test for me, it's like giving up smoking lol
I am interested in seeing how much power I will get out of her once everything is in and the HKS finally pushed its limits (only running at 50% at the moment)
Looks like a fun combination haha. My car should be ready in September too, maybe we should organise a cruise somewhere...
Nice, what are you getting done?
I'll be up for a cruise up until track day late September, need to rack up the k's on the new clutch, come October she'll most likely be off the road again for the work.
Same as yours but instead of cams I'm chucking on an SS2 turbo. Should be pretty quick once tuned. Hoping for 300 at the wheels
So we have got:
Haltech ECU
Tomei Cam Gears
You only need the one cam gear man... And also why the upgrade for the oil pump? Mine has held up so far with the abuse...
Might look into head studs and cam springs if you want to run bigger boost, these can be done on the car without lifting the head :yes:
Organise your entry for the track day in September hahaha
I might do. It'll be pretty rubbish as it's on standard shocks though haha. Also I have no licence or helmet or gear or fire extinguisher. I might aim for the next one hahaha
I have spare helmet and extinguisher you can borrow
Licence is easy to get $50
This is about as tempting as a kebab after a big night on the piss. I'll see how the build and tune goes with Paul. Might just unplug the boost controller and run it as rich as a Saudi prince if it's too quick for the suspension
If I'm going to upgrade 1 might as well do both.
I'd rather play it safe with the oil pump, minimize the chance of failure in the future
Might be an idea. What's the limit on boost with stock studs and springs?
Stock studs held up OK when i was running 24psi but eventually i would have done a headgasket... I would say 20psi on stock springs and studs to be safe as long as you have a good tuner... Others might have different opinions?
Most engines start having issues once they have been messed with (in regards to bearings and bottom ends and stuff) best leave it the way it came from Nissan and thrash... I thought mine may have proven that to ya by now :P
  • Like 1
Sounds good seeing as my MAP sensor will only let me run 21psi haha. I hope I land in a pit of money soon so I can come on the track day
if you use the intake cam gear you are going to lose your VCT as its a single unit and cannot be mated to the adjustable cam because well thats sorta what VCT is!.
go take it back and get them $$ back!
if not you could always sell it to someone else and they can flip it around and use as an exh gear.
The new clutch feels good, it will take a a little while to get used to it. Different friction point and it's a little heavier than my old one
Time to bed it in and get ready for track day next month :D
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
