So I've been to plazmaman. Apparently I have to shift the fuse box more to the guard.
So unbolt it, push it more to the left, redrill the hole then bolt it back in.
No where on their website does it say that shit needs to be moved....
Also the above piping, one is for the bov and the other is for the idle speed/control
  • Like 1
Picked up my headlights today from being cleaned and treated.
If you have a look at some of the front end picks of my car you would of seen how bad these were especially the drivers side.
I'm very happy with how these turned out
  • Like 2
Ah yeah i forgot to mention that! Mine is just a tech screw and cable tie lol
Lights look good on the car
Ran in to a small problem though, the bar doesnt fit with the new intercooler piping. Time for a bit of shaving
Just make sure you take a small bit at a time and do a good job of it... So many people hack them and just fk it all up!
Yeah that's the plan. We were discussing ways to do it Thursday night, keeping an even and clean look on both sides. I'll see how it turned out when I check on the car tonight after work
Hopefully once this is on and finish up the lines on the cold side, the rest of the gear should just fall in to place.
  • 1 month later...
Question for anyone whos following my build.
Plugged in the new haltech platinum pro, turn on the reds and the aircon fan switches on. Turn the car off, take the key out and the fan stays on as well as the reds. Fuel pump switches off. Turbo timer is connected but not turned on.
Anyone else come across this before?
Thanks dude. I'm happy with how the bay has turned out so far, still very far from my end goal.
As for the vct, the module was playing up since my last tune and it was holding the car back in 3rd gear so it needed to be replaced anyways so my mechanic decided to replace it with cam gears. I trust his judgement so we'll see how it goes when it gets tuned.
Speaking of tune, it's getting dropped off in the next few days :D
Can't wait until I get to drive it again
  • Like 1
  • 3 weeks later...
O.......k a bit of an update.
The car went to the tuners last monday, the wednesday before that he came out to my mechanics house and put a base tune in.
It was running very rich and rough, as you would expect.
While at the tuner, it was having a problem with idling. Sometimes it would idle fine, other times it would drop below 900rpm then switch off.
Eventually that got sorted.
Last wednesday my mate was on the phone with the tuner and I received the news that the car wouldn't be ready for mondays track day.
I was gutted that she wasn't going to be ready but I couldn't do much about it.
Last night while hanging out at my mates he gives me the news that the car is having further problems.
It's making 12psi boost on idle, sounds like it has a 2 step set up and won't rev past 3k rpm.
Tyler (my tuner) has been on the phone with Haltech directly and Adam from JEM.
Both Haltech and Adam have logged in to my car to diagnose the problem but neither of them can work it out.
Adam even suggested to tow the car over to him to have a look personally.
Haltech have suggested to swap out the ECU, which is being organised.
I can't thank Tyler (PVS), Haltech and Adam (JEM) enough at the moment. The effort and focus they are putting in to get my car up and running is crazy. This is the reason these guys have such a good name.
  • Like 1
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
