Hey all
Couple questions
1. Who imports / has track only cars?
2. What makes a car track only? looking at a r32 GTR
3. What are rough prices of them?
Thanks
Why bother importing one? There are enough GTR's sitting around in Aus that are so cheap you can just buy and deregister them. If you want a built up race car - what are you using it for? Sprints, IPRA, tarmac rallies? The best race car is one already built for the purpose you want to use it for.
Not always - it depends on what you want to do with it.
Remember things like Jap cages won't be accepted for most CAMS events that require a log-booked cage so you'll need to get that re-done.
Often your cheapest bet is to find a locally done race car on MY105 as Paul suggested. Initial cost MAY be higher but your final cost will probably be lower. But as a rule race cars are usually cheaper than street cars (at least they are a lot cheaper than building one yourself from a street car).
So if it's just a track day car then an import is fine. But if you ever want to do Targa or something similar you'll be struggling without spending the extra $$$. And it will be a lot easier to sell down the track if it is a track only car that can be used for more than just club sprints.
2c
  • Like 1
Every "fruited" GTR race only import I've had come through the doors has been a complete and utter shit box. Yes they have all the good parts but they are always tired and worn out.
Electronics are usually butchered with add on things installed upon add on things
Engine parts are usually old and well used if the car is a cheap one
Gearboxes often crunch and fall apart
Cages are really useless.
Brake upgrades often need seals, rotors and pads
Suspension usually worn out and leaking.
As others have said I'd buy a shell locally and build a good fresh car or buy one done already.
Seen and heard of so many cars that sound great on paper but turn out to be nuggets
Here's the link to my for sale thread:
http://www.skylinesaustralia.com/forums/topic/423367-r32-gtr-log-booked-race-shell-with-cage-non-registerable-sydney/
Can work out a good deal if you're serious, have a lot of other parts to help complete it as well.
hey mate thanks for the offer and it does look good.
but id really like to do it myself. Its as much of a hobby / time killer then it is to actually drive it
Seriously there is so much work in a track car build when started from scratch that basing it on someone elses work is a REALLY GOOD IDEA.
Thanks mate,
And why not here. only becasue it seems cheaper and with more fruit importing one
You'l find these fruits are often rotten bud...
I would definitely recomend to just get a shell locally that you can go check out in person if you want to start from scratch..
And time killer is an understatement! Lol more like time serial killer!
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
