couple of shots from Circuit Club:
1910002_441142296025444_9137792460351887
10384909_441141792692161_482144101492869
Went for a bit of a spin!
10524630_441141746025499_784410468464564
Had a blast and Dan came third overall for the day with a 1.08!
Best I managed was 1.12 so I definitely have a long way to go with my driving, but still a PB for me. And the D2's make a HUGE difference to my confidence, damn they pull up hard.
Anyway, the old girl is off for a few more changes, should be interesting when it comes back :yes:
  • Like 2
If you're running the D2 pads (I used to distribute them) you'll find they don't last a very long time. As dar as budget set-ups go I dont think they can be beaten. Best thing you can do to them is throw a set of Project Mu HC+ at them. We found them to work incredibly well with the D2 setup. You'll never look back.
I heading to wakefield tomorrow to wake my GTR up for the first time in a few years.
Last time I was there I ran a 1:12 and that was with about 260kw and 16x8" street rubber (old potenza GIII) and full trim with stock brakes, suspension and diffs. You definately have the potential to go faster :yes:
So Im hoping to quicken that time a little now with the extra work done.
Still has stock suspension and diffs, but better brakes, semis and a little more poke.
Should be interesting :D
Booked In to Sept track day yet!?!
Not yet! Need to see if the car will be running by then!
The kit came with street pads which got promptly thrown in the bin. We ran Winmax W5 pads which were f**ken awesome for the money. Highly recommended.
  • 1 month later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
