So where are these genuine T4 divided rears for GT35's? I can only find genuine divided T3 or crappy T4 divided ATP housings?
I was saying last night at our SAU meeting that someone was chasing a T4 rear... It was you :P I think Lithium had a heads up on where to find them?
Dumb - I went to get a link and realised it was only T3 divided, not that it should be a show stopper - but T4 would be more ideal due if nothing else to the commonality of T4 Divided "things".
I called GCG and apparently they only have non-genuine T4 Divided housings to suit GT35's.
Wouldn't recommend using them if you intend on pushing it at all
Sent from my GT-I9505 using Tapatalk 2
My mates Evo has run a few twinscroll HTA Turbos.
HTA3582R with 1.06 A/R Rear Housing - Made 450kW
HTA3586R with 1.06 A/R Rear Housing - Made 500kW
Difference is about 2-300RPM in spool.
The HTA3586R is the BEST all round forced performance turbo you can buy unless your running really big boost like 40+psi. But under 40psi, the HTA3586R will be more responsive and make similar power as the HTA3794R's.
I ALMOST went to a HTA3586R. But just didn't due to $$ that I was spending elsewhere on the car..
On a pissy 2 litre youd be right , on a Rb30 , the 3794 should walk away easy on less than 30psi i would have thought
I'd love to try a FP4294 or 3794 on a sohc, just the normal garret 4294 was a very good thing with a auto and
small 8.5 inch torque converter
cheers
darren
Edited by jet_r31
Yeah I reckon! The new Super94 (which basically outperforms the 3794/PT6766/pretty much any 67mm turbo in spool and flow apparently) is actually for sale for a REALLY reasonable price considering what it is capable of, here's hoping there are other turbine housings available on request for the bigger motor guys as the .85 seems a little small - though the Boostin Performance DSM trapped at 177mph so it would have to be putting out near >1000hp with the thing, so maybe the flow is suited and conventional wisdom could be overlooked in this instance:
ttp://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTFPSUPER94&Category_Code=Turbo-FP
I'd expect it would be totally streetable on a 3litre - imagine of street/drag weapon something like that could be? :wub:
here the link for the T4 TS housings for the GT35R 1.06A/R. I think the A/R is a bit big for me because im just chasing 400kw with something with reasonable response.
http://www.treadstoneperformance.com/product.phtml?p=1905&cat_key=595&prodname=Garrett+Turbine+Housing+T4+Divided+inlet+1.06+A%2FR+GT3582R
They are not very expensive aswell
Looks like an ATP housing, we were playing with a BW S300SX 8375 and a GT3582R (with ATP 1.06a/r T4 TS) housings a while ago comparing the general turbo stuff and there was a definite difference in quality etc - GT3582R on the right:
^ I think its got to do with the casting process and quality of steel used.
Yep - that is my understanding too. Here's one a 1.06a/r one from a E85 guzzling S15 race car from here which demonstrates what concerns me:
Anyone managed to find the T4 twin scrolls for the HTA3582 i would probably just bite the bullet and get one.??
http://www.streettunedmotorsports.com/parts/fp_hta_gt3582r_ball_bearing_turbo.htm
these guys offer t4 divided?
Thats the ful unit though im trying to source out a housing and maybe would make it cheaper because $2269. Is a lot and its not proven on RB25 though it has some serious potential packed
You know its going to make insane power and lag will be very little in comparison to equal sized turbos, the results would be the same sort as mine just on a higher scale!
the price is what is holding me back but if i get a fat tax back this is what im getting. if its not as i like resale shouldnt be hard with a few hundred off the price
Depends on where you want to compromise and what you think you will get the most reward from, you can definitely save a reasonable amount of money and still get respectable performance - however with this there is less risk you are going to look back and think... Maybe this could be better, but now I have spent the money.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
