Ah just say this model skyline was the Bathurst "SPECIAL RACE ADDITION" and it was released with a top mount turbo officer. Get a little tag made up saying genuine Nissan on the turbo and manifold somewhere and bobs your uncle. Lol maybe. ;)
Ah just say this model skyline was the Bathurst "SPECIAL RACE ADDITION" and it was released with a top mount turbo officer. Get a little tag made up saying genuine Nissan on the turbo and manifold somewhere and bobs our uncle. Lol maybe.
Edited by WMDC35
And seriously what can they say to that? Nothing I would have thought. How can they prove it's not?
They don't need to. They just send you for an emissions test/what ever else the hell they want you to do.
If your on jungle juice would you pass with a 400 cell cat in place? And if you go through the hassle once and show following offices your EPA emissions test has past certificate perhaps one would be ok? Added things if your not getting up it and driving hard around town you should be right. I also love screamers myself but on the street having it plumbed in is the go for noise level reduction. But what ever you do they'll do one better at times. Other thing would be have a tune in your ecu to switch maps to a EPA safe tune perhaps? I dunno lol just trying to hope when I put my new top mount kit on I wont put off the road. Oh well I'm leaning towards a hta gt3582r at the moment with a twin scroll ass on it. Unless stao can make me something close to it's performance.
Edited by Joshbigt62r
could be stupid question....
would there be a twin low-mount option for an RB26 with these HTA turbos?
I dont think its a stupid question... It was asked a page back i think and its not an off the shelf option as far as i know!
There is an option, I'm just not certain how good it would be - Owen Developments in the UK do a few custom FP based combos which FP themselves don't release to address customer requirements in the UK: http://www.owendevelopments.co.uk/article/76/NEW_Skyline_R33-34_twin_GT2668_HTA_turbos/
They've also sold HTA4094R turbos and if I remember a couple of other interesting HTA based units which I am fascinated that FP themselves don't market.
Nice find...
As always :yes:
wonder if there are any results floating around at gtr.co.uk - will have to have a dig
1100 pounds though... each. yikes. less 20% but still...
in the old money... would these be classified as bigger than 2530/-5's?
There is a guy (mentioned this stuff recently in this thread) on the UK forums that installed a pair on his and from memory it had no surge issues or anything, but his engine failed before he managed to get a full tune into it :( If the compressor doesn't choke on the turbine or smaller compressor cover (not convinced it won't) then I'd peg it to be capable of outflowing -10s and spool somewhere between the -5s and -10s. Hard to say though
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
