Hello
So its sorta hard to explain, but ill try my best.
I have a 1998 R34 GTT Skyline, It has a rb25det NEO. It has no engine mods other then an oiled HKS Pod filter, Apexi Front mount intercooler and an Apexi AVC-R Boot contoller.
I have a problem (is most noticable in 3rd gear) where when i hit apoximatley 5000rpm power drops and from outside the car it sounds like im on red line apprently. I am still obtaining the same out of boost and injection percentage according to the Apexi AVC-R. When i set the boost at stock pressure the problem goes away. However the problem accours again when i turn the boost up. Starting at 9 psi and onward up to 11 psi! (i havent tried to go any higher) iver also tried it with traction control on and off and it makes no difference.
Please help, Do i need a tune or new plugs and coils, etc...
Thanks for your help, Im new to all this.
Alex
Edited by Shelford93
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/
jase_c I have hit boost cut before, this problem isn't as violet as that it doesn't jerk or throw me around it just looses power when I hit about 5000rpm and then it seems to get past it at about 6500rpm
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6886514
I would use a compressor and regulator, but you could perhaps use a bike pump and gauge?
Just remember the pressure it takes to open the actuator is completely different to where it will crack open normally, as the manifold is filled with pressure when the engine is running.
Best to simply leave it on low boost if bumping it up is causing issues, unless you tune it...
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6886811
Seems your running the stock ECU as you don't mention an aftermarket.
34GTT NEO's seem to always encounter this issue.
you could put an R32 actuator on there and stay on/around 10PSI
until you do get an aftermarket ECU or 'Nistune' and get it tuned as suggested by others.
Edited by Sinista32
  • Like 1
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6886820
My 34 is doing something similar around 4500rpm under load on the dyno but i think it has something to do with maxing my air flow meter out (240kw). i have some video of it i might try and upload, see if its what yours is doing
https://www.sau.com.au/forums/topic/426825-r34-gtt-problem/#findComment-6887883
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
