For use guys that are running a flex fuel set up. Which content sensor are you using and what did it cost? I can get a genuine gm sensor which is the flow through type for around $200. I have not seen to many more for sale that are available locally
https://www.sau.com.au/forums/topic/434195-which-ethanol-content-sensor-to-use/
  • 7 months later...
If I was to use an Adaptronic Select plug in ECU will this be compatible with it?
Yes, but remember adaptronic ECU doesn't truly do flex fuel - as it doesn't have the capability to blend maps like say a haltech as such.. it just adds/deducts timing and compensates fuel based on rpm/load.
good enough if you're mainly using E85 and pop in the occasional 98 or blends
Do you just pop the sensor inline in the return line then call it a day?
yepp and connect the sensor up.. if you're really tight you can connect the output to a digital volt gauge to measure ethanol content.
0V = no ethanol
1V = 20%
2V = 40%
3V = 60%
4V = 80%
5V = 100% ethanol
  • Like 1
I was reading a paper linked on the adaptronic forums that talked about ethanol content and knock resistance - peak ignition timing for port injected engines is at about 40% ethanol content and additional ethanol doesn't benefit knock resistance. it was interesting reading as it means your fuel map needs to vary from 0% to 85% ethanol (to get mixtures right) but the ignition map probably only needs to vary between 0% and 40% ethanol content. (I say probably - I'm not a tuner!). So even blending maps may not produce a perfect result, although it would be conservative with the ignition timing on a partial blend which is a safe option.
quick question, I'm looking at adding an ethanol sensor to my Link G4 sometime before the end of the year. The wiring manual for the continental sensor shows a +14v output from the ECU to the sensor, but there is no such output of voltage from the ECU. I'm thinking this is just a power source from battery/ignition but obviously I don't want to fry the ECU so can anyone help me out.
I feel like this is maybe a silly question but oh well lol
0V = no ethanol
1V = 20%
2V = 40%
3V = 60%
4V = 80%
5V = 100% ethanol
Hmm.
But the sensors output a frequency, 50 to 125 hertz if I remember correctly.
The whole point of the zeitronix box is to convert that to a voltage. If you didn't need it why would people buy it?
Edited by Ben C34
Got a link to the thread mate?
Can't find it on adaptronic forums, i think it was one of the discussions on flex fuel. Here's the actual paper though (see link down the bottom to PDF):
http://dspace.mit.edu/handle/1721.1/69496
Your correct, use a +14v ignition switched supply.
Thanks
I figured as much, the wiring drawing just confused me because it shows a 14v supply straight from the ECU. Figured that must have been just a switched power supply, but wasn't real keen to blow up the ECU so had to ask lol
Thanks
you got a diagram of that mate?
also anyone know where to buy the sensor plug?
I have sensor here but not sure how to wire it...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
