I get on average 260Kms a tank with my GTT aswell. Engine wise it's completely stock. I've cleaned AFM changed the fuel filter, fuel filter was completely clogged I noticed a slight difference in fuel consumption, maybe I'll have to go for the O2 sensor and new plugs see if that helps as well
Also if someone has put a low temp thermostat in, or yours is stuck open, then that will also add to poor fuel efficiency. Cold crank enrichment tapers off at 70C so the quicker she gets up to temp the better.
This. I put a Nismo thermostat in my Riceline, water temp now sits at 60C unless I'm at a track day. I struggle to get 12L/100kms, when I first bought the car I easily got 9.5L/100kms on the highway
I do do alot of short trips, I'm running PFR8 plugs with a 0.9 gapp,
Short trips, incorrect heat range plugs - no wonder you have absolute crap economy.
Try running a 6 heat range for starters. And plan your trips better so the engine operates at the correct temperature for most of the time.
So OEM/stock thermostat is best for fuel economy? What about oil cooler with built-in thermostat?
Mines got a oil cooler with no thermostat, oil temp sits between 70-80 degrees. I run BCPR6ES plugs with the standard gap, which is 0.8mm from memory.
I've found V Power to give me greater mileage than BP Ultimate for some reason too
I ran those before the PFR8S and it was the same thing, well the owner in Japan did fit quite a few Nismo parts to the car, I'll check what thermostat is in there and give the AAC valve a clean aswell, is there a way I can get error codes through a power fc by any chance, thanks.
And whats the difference between the BCPR6ES and the BCPR6E? And could some refresh my mind the lower the number the higher the plug temp correct? thanks.
Edited by MrRx7s3
Yep lower number is hotter. Has anyone checked their timing? That would have an impact on economy. Also should be talking litres per 100 ks as too many variables with a 'tank' of fuel.
true but seriosuly when were talking a difference of 550km- 250km, i dont think brimmed vs filled is going to mean too much.
Its not the difference of how full, but how empty it is when you fill it. Accuracy of fuel gauge and how far you are willing to with the gauge below the E.
mine been tuned a while back after i re-did my fuel pump mod for battery voltage, crap economy, around 300km on full (72L tank IIRC), o2 sensors turned off, bcpr6es plugs, no leaky injectors, although i do short trips (10km) each way to work, low temp sender perhaps buggered?
Install a wideband o2 and see what your car is doing. I've seen lazy tuners who don't even care too much about off boost injection maps and just rely purely on o2 closed loop to work out the mixtures.
I find mine is chewing up a fair bit of petrol as well. I've put some fuel injector cleaner in which should help, also going to replace the spark plugs and clean the AFM sensor to see if that makes a difference.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
