Anyone here using Radium Engineering Oil Catch Can?
Their product is very popular over at FT-86 crowd, and my friend has one and seems very high quality as well.
Also this catch can size looks similar to the Nismo Catch Can style, which is what I want for having a stealthier looking engine bay.
Edited by etang789
  • Like 1
https://www.sau.com.au/forums/topic/443367-radium-engineering-oil-catch-can/
Just had a look on their website (radiumauto.com). USD$165 for the single universal as pictured above. 6 fl.oz capacity (175mL?).
They like much better quality than most I've been looking at. I'm seriously tempted. Good find.
Yea you can also get the Competition Catch Can with more capacity but not sure if it can fit where Nismo locate theirs.
Here is an article review
http://www.motoiq.com/MagazineArticles/ID/2449/PageID/4428/Company-Profile--Radium-Engineering.aspx
Edited by etang789
Here is the picture of the Nismo Oil Catch Can which I think is the ideal location for a catch can.
BTW is the RB26 valve cover breather hose size 22mm ? Not sure which fittings to get...
Edited by etang789
  • 4 years later...
Found someone using Radium Engineering Oil Catch Can with RB26 . Not a GTR thou... http://www.superstreetonline.com/features/1802-1984-nissan-skyline-2000-rs-x-dr30-the-last-straw/
Nice and short routing like what I had in mind, just like the Nismo Catch Can.
Edited by etang789
  • Like 1
Those things look pretty, but the size makes me question how functional they're likely to be on a high revving, highly boosted RB.  I'd be thinking they will take about 300ml combined and then dump whatever else gets spat out straight into the inlet tract.
They do look nice however.
  • Like 1
Generally for motorsport you need to have a catch can which has more volume then your engine displacement, aka 3L ones for Rb's or like 20 of these?
Personally i'd say you can't go past a good custom battery tray replacement one with proper baffles/foam, and a sump breather. Or if you really want something off the shelf then a hioctane style one at least though volume may not be enough
  • Like 1
Agreed. Nothing really good off the shelf. Custom is the way to go.
  • Like 1
And for CAMS sanctioned motorsport at least, unless it is set up as an oil separator returning to the engine via PCV applied to one rocker breather and the bottom of the can to the other rather than a catch can (So manifold vacuum when off throttle draws oil back in via the breather)  any RB turbo will need at least 3L capacity. I am just about to build a new one for my HR31 and will be making it about 3.5L with an oil return to the sump and a proper filter on the outlet, one track I run at makes the 20DET hoist a lot of oil out. Hard braking followed by a very hard right hander and immediate full power twice in a lap, it spits out up to 500ml in a handful of laps, take it to Phillip Island and it did not put that much in the can over 500KM.
You are not particularly likely to get pinned for it being to small at most  track days but who needs to give a grumpy scrutineer something easy to knock you back for.
I use two of these  with the bottom cut off sitting inside a tank with fuel tank foam.
the base of the tank has a ball valve on it so at the track I can leave it open to drain to sump and all other times it just collects in the tank and I clean it before a track day because it gets sludgy due to moisture over time.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
