Hi guys, ive tried searching for info but cant find what im after even through google. I'm sure its all on here somewhere but just curious as to the upgrades/improvements that were made through the R32 GTR (just base model is fine) year models as obviously 'series 1' always has its issues to be revised. I am looking at a 1994 model at the moment which is the last of the R32s so I figured it would be the best year to go for having hopefully had most weaknesses addressed and even cosmetic upgrades made. Could someone maybe list the differences between the year models or maybe post a link to a discussion that will answer my questions
Thanks
Not much really.
From memory, R32 GTR's built from 1989 to early 1993 all have Push Type Clutches.
From May 1993 to the rest of 1994, all have Pull Type Clutches.
Headlight Globes from Pre 1991 used a H3C Globe, Post 1991 all used a H1 or H4, you will have to check.
Slightly different centre console interior trims.
Supposedly, R32 GTR's built from 1992 onwards, Nissan had improved the oil pump drive collar as the one's built before 1992 tended to fail at high power setups.
Base model exterior wise are all the same.
  • Like 1
There is more information than the below. Biggest change would be that the later model 32 GTR's had side intrusion bars and the issue with the crank's oil pump drive fixed (amongst other things) Cosmetically they're all identical externally. Depends on whether they had any optional Nismo bits fitted etc.
Being a very old car, getting a newer model will only get you so far as 99% of them have been flogged within an inch of their life and need a lot of work.
Below was from one of the other GTR sites
Total Production 43,934 1989 -1994
89' 4,555
90' 8,426
91' 7,081
92' 7,961
93' 6,204
94' 7,465
GT-R 40,390
Nismo 560
Vspec 1,453
Vspec II 1,303
N1 228
Last chassis number :
Regular GT-R BNR32-314649 November 7,1994
Vspec BNR32-313609 October 13,1994
Vspec II BNR32-313930 October 20,1994
3 runs of the R32 with chassis numbers:
Early August 21,1989 BNR32-000051 ~BNR32-017466
Middle August 20,1991 BNR32-212001 ~
Late January 1993 BNR32-300001~ BNR32-314649
Color Codes:
Early - Middle:
326 Crystal White
KH2 Gunmetal Grey
KL0 Super Silver Metallic
AH3 Red Pearl
732 Black Pearl Metallic
BL0 Greyish Blue Pearl - Special Order
TH1 Dark Blue Pearl - Special Order
Late:
326 Crystal White
KH2 Gunmetal Grey
KL0 Super Silver Metaillic
AH3 Red Pearl
R32 History:
5-22-89 R32 is introduced
8-21-89 GT-R on sale
2-22-90 GT-R Nismo Introduced
3-11-90 GT-R Nismo On Sale
7-19-91 GT-R N1 introduced
8-20-91 Minor change - Middle
4-20-92 Skyline Autech version introduced and on sale
2-3-93 GT-R - Later - Clutch from push to pull
GT-R Vspec Added
2-14-94 GT-R Vspec II Added
  • Like 3
One fact that is not common knowledge and I can't quite pinpoint when this feature was added is heated side mirrors.
As you can see in the attached pics, the top button when depressed heats up the glass. The other pics are of my ADM which is built on a Series 1 platform and it doesn't have the same feature and you will note the selector that chooses R and L is also different.
Anyone else got this feature/ My V-Spec 2 is an August '94 build.
Cheers,
Bob.
  • Like 1
  • 5 months later...
Cheers,
Bob.
It was an optional extra on the earlier models. Might be why its hard to pinpoint.
  • 4 weeks later...
simply the different the oil pump drive collar. no other differences.
To be pedantic, its just oil pump drive. You only need the collar if you are fixing an early crank.
If I was ever to buy another Skyline it would have to be a 32 GTR, the only true Godzilla, to me anyway as that what it was dubbed when I watched it slaying the others on the track.
Calling the 33, 34 and 35's Godzilla is like saying the 31 is, but then I'm old and grumpy.
The 94 would be the pick of the litter, its bloody hard finding anything stock or good though, there are some out there but the cream is few and far between.
When I went looking a couple of years ago I didn't see one good car for sale (stock with under 100k), the undersides and quarters are a issue, I went looking for a stock car with history which had been garaged, lots of ads said they had one but inspection told a different story.
Good luck, I really hope you have better luck than me.
Best looking car with real racing history in Australia IMO.
Now I want one, LOL.
  • Like 1
to add to the discussion
you may find your mirrors are actually the heated type but are not connected and do not have the switch. Mine is a Nov 92.
I say this because I replaced my original mirror glass due to being below par. (worn hardened cracked surround)
Both were of the heated variety but as said above not connected and I did not have the switch.
It may be the came this way but when you optioned it they connected and inserted the switch in the panel - perhaps anyway.
Easy to check too :)
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
