The 180 has seen some upgrades too.
I got the Street rubber switched over to the Nismo LMGT2 rims. I love them. I couldn't care less about flush and stance and that shit, I love them cause they fit the car so well!! They are 17x8 +35, 17x9 +38, made 1996.
After some discussion with another member at a track day, I decided to drop the car off to Road2Race Chassis tuning up at Gosford. I got a call back a little while later with a plan of attack. Old bushes were replaced with nice new stiff ones in the front LCAs, the steering rack bushes were disintegrating so they got uprated items. The swaybar link ends were all serviced, and washers/hardware renewed and assembled correctly... The car was the aligned with purely the track in mind -3.5 degrees camber on the front :)
The car was Corner weighted for my weight- with a 1/2 tank of fuel, it came in at 1197kgs.
10268618_760352777329367_758010080689815
I also got a hold of some Michelin S8D Slicks to give a go at the track (they can be seen above). I put them on the Gram Lights, as they are 24/64r17 all round. Then it was time for the track. I was determined to get into the 60s at Wakefield so I booked in for a Trackschool trackday on the 28th. My previous 3 or 4 trackdays at Wakefield hadn't seen me improve from a 1:10.
Had a ball, learnt heaps from having Boz ride along for a couple of sessions. Even though the timing equipment wasn't working great, it popped into life for the last session of the day.
And I got my goal - a 1:07.6. Pretty bloody stoked with that. I think the Car has the ability to get into the 6 second range how it is now, with better temps, and me doing a perfect lap to my skill level. Couldn't believe I smashed my PB by that much. Using my optimum sector times, it has a 1:06 in it.
Anyway, here is a Pic of the car down there, thanks to Daleo :)
10366324_10152470469077392_6533650256747
  • Like 1
I heard that Silver GTR is a slow nugget
Like your snorer
I heard it doesn't even go. :whistling:
#waitingfornicktocallmeajerk
Jerk
Just because I broke it again lol
I'll fix it again
Then it's on lol
Forgot to mention, before the last trackday, I switched over to Brembo calipers on the front, and went to a BM57 master cylinder. Still running A1RM pads, but think I might upgrade to something gold coloured for the future...
So, basically caught up to speed now.
This is what I've been doing over the last couple of months.
After returning from the Wakefield day, I put the car up on stands to go over it and found that there was streaks of black goopy shite down the underside of the car. Quickly found the source as the gearbox bellhousing. I know things were getting a little nasty in there, so it wasn't a surprise really. Decided to take out the gearbox... the morning before PM shift at work :)
10417659_10152507757854669_2445376121128
10361413_10152507757964669_4712344990656
A little damp....
10414577_10152507758069669_8483530425584
10451711_10152507758199669_8313596607700
So I took the box off to Award Gearbox and Diff for the once over. Got a call back a few days later that reverse was rooted (lol), a couple of synchros were on the way out, and some of the bearings were worn/collapsed. Obviously the front seal was pissing oil out too. Apparently its a bit of a knock on effect, when the spigot bearing wears, allows play on the input shaft bearing, which in turn flogs out the front seal. I had a throw out bearing sitting round, so got them to press the new one of those on while they were at it. No Point not doing it while the box was out.
So, got the gearbox back, and installed a new spigot bush (soak them in motor oil for a while before hand, they are porous ;) ), getting the old one out was a heap of fun....lol. Took the clutch off, and cleaned it all up, and chucked the box back it. Bit of a challenge by myself, but after dropping the front subframe a little bit, it slid on in. Filled it with ATF (as per awards recommendation). Hopefully it lasts a few more trackdays of punishment ;)
Council clear up special that carpet.
Washed and rinsed it up. Much nicer to lay on that than the cold concrete floor!
lol i have a persian rug to lay on too!
nice write up mate. loving it.
Enjoying the Micra build as well, mate!
From graveyard to awesome little rocket!
cheers mate! once the bambino has arrived ill get back to it and get it track ready!
fo r now ijust have to live vicariously thru your thread! haha!
Just have a look at the rest of the vids on youtubes.
Might find some action.
Unfortunately last two trips have had really bright overexposed gopro footage. So I haven't uploaded it. Will have to sort it out before smsp.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
