Hi guys,
Has anyone replaced their exhaust middle muffler with a resonator? If you did, what happened to the noise levels?
I've got an R34 GTT sedan with an R33 HKS Super Drager (the one with the massive rear muffler) modified to suit, but the middle muffler is sitting really low and regularly scraping. I'd like to replace it with a resonator (to run under the transmission tunnel) but I like the relative quietness of the exhaust system as it is, so I don't really want to make it louder...
Also, what catalyser would you recommend to flow 300rwkw? Needs to bolt on to 3" flanges. I'm thinking a 200cpi metal cat of some kind. I've got an X-Force ceramic high flow currently but it's suspected of restricting flow.
Thanks!
Edited by V28VX37
I use a Venom Cat with 5" body, that should allow you to hit that power goal. See link...
http://www.ebay.com.au/itm/3-Nissan-VENOM-High-Flow-Cat-Skyline-R32-R33-R34-GTST-GTR-S13-C33-A31-/251462134106?pt=AU_Car_Parts_Accessories&hash=item3a8c4fa95a
As for replacing the muffler with a resonator, it really depends on the quality of both. But typically a resonator should muffle the sound reasonably well at low RPM's, though at higher RPM it will change the note but not muffle the sound as well as a standard muffler. I'm currently looking to do the same with my car - I've found these resonators which seem to have pretty good reviews that I'll probably go with:
http://www.ebay.com.au/itm/Vibrant-ULTRA-QUIET-Resonator-3in-inlet-outlet-x-14in-overall-length-/281208154580?pt=Motors_Car_Truck_Parts_Accessories&hash=item41794fe9d4
  • Like 1
I use 200 cell 5 inch cats, similar to the Venom ones, they flow over 400kw. Not cheap though, around $200, and they don't have the flanges welded on yet.
The Venom 100 cell ones come with the flanges already welded in the correct place, and for a very reasonable price. I would buy one of them seeing you already have the cat back, they should flow even more, but I believe 100 cell isn't 'Legal' afaik.
Resonators are crap. Perhaps you can just get the muffler tucked up a bit more?
mine sounded just right with a 100cell 4inch cat, 3 1/2inch system with 3 1/2inch jap resonator and a 3inch Xforce muffler, that's all, sounded like quality and just like a well breathing engine not a shit loud muffler and crap breathing engine
Venom do 200 cell ones too last I checked (which was a while ago) if this is important to you.
That would be the best option then, and will flow more than enough for OP.
Thanks guys! I've just contacted Venom to check availability and price of the biggest 200 CPSI bolt-on cat they have with 3" flanges.
Good idea, thanks Scott. I just had another look at it and there's at least an inch and a bit of space above the cat & mid muffler, I better take it to an exhaust shop.
Just out of curiosity, why are resonators crap?
I think there is a large variety of resonators on the market and the materials used and method of construction obviously play a part in how well they work.
I have a 5inch 100 cell Venom cat, a 3in resonator about 500mm long and a 3in Japanese muffler ( had a job to find one that was 3in right through - many are stepped down to 2 1/2 in just before the tail pipe for some reason). This system sounds good and is right on the edge for legal loudness. This is measured at 3000 rev/min and its is in fact quite a bit louder at 6 - 7000 rev/min which is why i keep the revs down around town!
I can supply a 3" resonator 5" diam. or 3.5" bore , 4.5" diam. 409 s.s. perforated tube with expansion joint , packed with inox (high temp.Both 400 mm long.
You really should contact admins and get a dealer membership going if you want to sell stuff. Sounds like you sell some quality products at good prices.
I am but a small fish in a big pond but my mufflers are designed to give the best possible performance without being influenced by other requirements such as sacrificing performance for cheapness.
Good for you. You're still advertising your products and you are running a business - pay up like everyone else.
Agreed with Ravi, we are all for products like yours but you have to do what everyone else does and pay for the right to advertise.
Hypergear is a small fish in a big pond and now he has a huge following on SAU, however he pays to advertise on here just like every other business.
Like using 409 stainless so it rusts just like mild steel?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
