Probably mate if my yellow 34 was parked nearby definitly was me. Feel free to have a chat with me, mustve been busy or a day i wasnt paying too much attention :)
Still a white 34 GTT sneaking up sally's corner road, wondering who that is.
Spotted a silver R32 GT-R with V-Spec II wheels on it leaving Castle Towers from the David Jones area parking today around 2.15pm, I was in my green C34 Stagea.
Spotted a black R34 GTt (following a black M35 Stagea) leaving the carpark of the sports grounds at Masonic Schools Oval in Baulkham Hills. I was getting into my dark green C34 Stagea, this was right around 9.45pm or so...
Just watched an R33 GTR with TE37's trying to do a U-Turn in peak traffic on the Anzac Bridge. :unsure:
There was lots of beeps before he gave up and reluctantly made his way across. :dry:
Spotted a silver 33 gtst yesterday afternoon down smithfield fairfield way, he saw another skyline and thought it would be a good idea to limiter bash 1st to 2nd. Another red 33 gtst with fmic shortly after. A white 33 gtst on Cunningham st Fairfield between 6 & 7pm. A 33 4 door in doonside at 7ish.... A white 32 GTR parked up outside the ARDC shop at SMP most of yesterday.
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
