Probably mate if my yellow 34 was parked nearby definitly was me. Feel free to have a chat with me, mustve been busy or a day i wasnt paying too much attention :)
Still a white 34 GTT sneaking up sally's corner road, wondering who that is.
Spotted a silver R32 GT-R with V-Spec II wheels on it leaving Castle Towers from the David Jones area parking today around 2.15pm, I was in my green C34 Stagea.
Spotted a black R34 GTt (following a black M35 Stagea) leaving the carpark of the sports grounds at Masonic Schools Oval in Baulkham Hills. I was getting into my dark green C34 Stagea, this was right around 9.45pm or so...
Just watched an R33 GTR with TE37's trying to do a U-Turn in peak traffic on the Anzac Bridge. :unsure:
There was lots of beeps before he gave up and reluctantly made his way across. :dry:
Spotted a silver 33 gtst yesterday afternoon down smithfield fairfield way, he saw another skyline and thought it would be a good idea to limiter bash 1st to 2nd. Another red 33 gtst with fmic shortly after. A white 33 gtst on Cunningham st Fairfield between 6 & 7pm. A 33 4 door in doonside at 7ish.... A white 32 GTR parked up outside the ARDC shop at SMP most of yesterday.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
