Probably mate if my yellow 34 was parked nearby definitly was me. Feel free to have a chat with me, mustve been busy or a day i wasnt paying too much attention :)
Still a white 34 GTT sneaking up sally's corner road, wondering who that is.
Spotted a silver R32 GT-R with V-Spec II wheels on it leaving Castle Towers from the David Jones area parking today around 2.15pm, I was in my green C34 Stagea.
Spotted a black R34 GTt (following a black M35 Stagea) leaving the carpark of the sports grounds at Masonic Schools Oval in Baulkham Hills. I was getting into my dark green C34 Stagea, this was right around 9.45pm or so...
Just watched an R33 GTR with TE37's trying to do a U-Turn in peak traffic on the Anzac Bridge. :unsure:
There was lots of beeps before he gave up and reluctantly made his way across. :dry:
Spotted a silver 33 gtst yesterday afternoon down smithfield fairfield way, he saw another skyline and thought it would be a good idea to limiter bash 1st to 2nd. Another red 33 gtst with fmic shortly after. A white 33 gtst on Cunningham st Fairfield between 6 & 7pm. A 33 4 door in doonside at 7ish.... A white 32 GTR parked up outside the ARDC shop at SMP most of yesterday.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
