EDIT - I wanted to leave this complete build thread untouched to show the slippery slope of the GTR build / restoration process. How sometimes things can go from mild to totally wild when attacking nearly every problem with the "while I'm in there" and "do it right, do it once" philosophies.
Just so you know, this project ends with a completely new 2.75L stroker engine on a BW EFR 8374 turbo...but it's a fun and informative read throughout. AND It's still under construction.
Greetings from up over?!
While I'm new to the GTR world, I am not new to cars. Actually I had recently sold my MKIV Supra Hardtop TT and went to look at a used R35 GTR that a local guy had for sale. I was SHOCKED to see his shop and found that he had two R32's just collecting dust. I asked some questions and we struck a deal on a Grey 1990 R32 GTR. The car had a slight intermittent rod knock in the higher (4k) rpm range and just coming from a TT inline 6 DOHC engine I figured it wasn't anything I couldn't fix. So I bought it, brought it home, and cleaned it.
So far the car looks to be in EXCELLENT condition with no signs of wreckage or anything. I am amazed that it made it to the US so recently in such good condition. This car will be 25 years old and will then be legal to drive here in the USA in Jan of 2015 so in the meantime I'm giong to address the rod knock issue and build up the car. Expect some pictures and information to follow in this thread.
First night was diagnosis of AC issues. Previous owner had cut the wire to the relay and wired it to a switch to force the AC on. I fixed this wiring properly and ran through the diagnosis on the AC setup. I found that I had issue 25 (sun sensor...typical), ALL of the 3X codes (31, 32, 34, 35, 36), and an out of range sensor for the suction air temp. I fixed the suction air temp with a 2.2k resistor I had and investigated the "mode select actuator". It was stuck fully extended to the DEF position and I helped it return back to the other positions manually. After pulling it apart I found that it had one broken gear tooth at the all the way extended position and I figured it was something I couldn't fix. I found the KUDOS MOTORSPORTS website and ordered the part. While I was on the website I saw that the GT2860 -7 turbos were apparently on sale for cheaper than I can get them stateside so I picked up a new pair of those and a pair of the spitfire coils (I hear they go bad as well). I'm sure they will make for a VERY fun street car.
I also realized that the car's ignition key didn't work with the doors or trunk so I took them apart, found that by switching the tumler parts around that I could use 5 of the 8 and still use the ignition key for the doors so I got them working 100% for $0.
My plans so far are to pull the engine this weekend and start the tear down so I know what I need to repair and to address the crankshaft issue (collar installation) at the machine shop. If all the bores check out good (I'm sure they are the car runs great), then I will order some factory bore size 86mm forged pistons for the engine and likely cheaper conrods (might as well put some manley or eagles for the extra insurance).
I tuned my MR2 turbo road race car (4th season straight sill kicking!), on an APEXi Power FC and hand commander, but I think I would likely go full Haltech PnP this time around as a laptop tune is so much easier to do. I learned the lesson on high boost and ceramic turbines with this car. Actually I learned that boost isn't all there is to high rpms...they eventually just overspin from freeing up the flow of the engine despite keeping boost under a set psi. Yep my ceramic wheel vanished and the car has since received a billet precision 557E turbo (which may be an AWESOME super-responsive turbo for a GTR if anyone would try it sometime?).
Any advice or input will be appreciated greatly. Also I'm thinking of dumping HICAS while I've got the engine out and wanted feedback on how far I can go with this while it's out.
Thank You,
Patrick Harris
  • Like 3
https://www.sau.com.au/forums/topic/447384-r32-gtr-build-in-usa/
check the valve guides
clean up the valve bowls
remove the exhaust port humps
gasket match the ports, exhaust manifold, turbo housings
clean up the casting on the oil and water ports between the head and block
consider deleting some hoses and the oil/water/cooler thing under the intake manifold
consider some better cams
don't hesitate to tighten up the stock valve lash
Edited by black bnr32
  • Like 1
Thank you and keep them coming. I worked only a half day today and made it to the shop for 1pm. By 5:45 I had the engine and trans out of the car. Didn't read a single instruction online at all. These cars really aren't THAT hard to work on but YES I 100% agree with you - The jumbled mess under the intake manifold will be relocated or removed...HICAS included!
someone definitely got into the bottom end as the oil pan had orange high temp RTV on it. The rear turbo was replaced at some point and orange RTV was all over that as well (honestly didn't get to look at turbos much yet) but they weren't pouring oil from them anywhere. Also someone had a different clutch disc in there, but it looks pretty worn so I'll still be replacing it. AND someone had replaced the engine mounts which is a shame because I ordered some new upgraded ones already.
I'm eager to put my mic on that crank this weekend (labor day long weekend for us) and see how bad that knock was (it was still intermittent under decel...not accel), and I'm well on my way.
*That's me in the white shirt and my brother in the middle and a friend (who LOVES NISSANS!) on the left.
Edited by HarrisRacing
  • Like 1
More news.
Finally got into the engine, but I wasn't the first one. Someone at least dropped the pan and diagnosed the damage before me, but I truly don't think they really tried to fix it.
REALLY BAD NEWS. Crank is trashed.
Rod bearings on #5 and #6 both spun. 6 bearing was super thin and broken.
Pretty much all the main bearings are trash. 5 out of the 7 of them simply "fell" out of the block on their own and would no longer hold into the spots. (see picture of strained bearings).
Block and Girdle Caps look great and MIC out round very close to the stamped sizes on the block. The bearings did their job and I'll be replacing the parts completely on the ones that spun.
Pistons 1-4 look great like the piston and rods complete could be reused.
.012" reduction in acceptable diameter on rod journal #6...so I started debating the grind .020" smaller than factory but then...
I get to the crank journal check and start with the dial on the center bearing...FAIL. Crank is bent .014" in the middle!
I marked the low spot on the crank and checked the other mains next to it...both are high (not as high as .014"), but it paitned the picture of a badly bent crankshaft.
Turbos are stock and both look to be in good condition (no oil, nomial shaft play). The rear one was rebuilt at one point because the name tag is bead blasted a bit compared to the front one. They are definitely good enough to sell off as spares or for someone to get cores for rebuilding.
I decided while I was at it to gasket match the turbo manifolds to the old gasket. I think I'll stick with these after porting. Should be fine on the -7 turbos and later I'll likely go single as opposed to spending all that on Tomei manifolds and such.
Now the big question (and I'll ask elsewhere), which stroker kit should I go with?
Patrick
More news.
Rods on #5 and #6 both spun. 6 was super thin and broken.
Pretty much all the mains are trash. 5 out of the 7 of them simply "fell" out of the block on their own and would no longer hold into the spots.
.012" reduction in acceptable diameter on rod journal #6...so I'm debating the grind .020" smaller than factory then...
I get to the crank journal check and start with the dial on he center bearing...FAIL. Crank is bent .014" in the middle!
I marked the low spot on the crank and checked the others...both are high (not as high as .014), but it paitned the picture of a badly bent crankshaft.
Turbos are stock and both look to be in good condition (no oil, nomial shaft play). At least good enough to sell off as spares or for someone to get cores for rebuilding.
Patrick
HKS stroker brah
Or get an RB30 and Stroke that.
Was the RB30 in any locally delivered car in the States?
No...that's why that option is pretty much out. I'm sure freight would kill me.
I can get the BC 2.9L stroker kit for $4800 or so US. I was already budgeting $1400 for rods and pistons, so this is like a $3400 crankshaft adder. In all honesty I would be looking at a NEW RB26dett crank either way because I don't want to mess with regrind etc after I have seen what happens inside these engines first hand, plus the fact that there aren't piles of them in the junkyards. Of course the stroker comes with a better powerband.
I can get Tomei for around $5000 US. From what I understand the Tomei is lighter and is shorter stroke...so slightly less displacement, but I'm sure it's still quite responsive. They offer two different pistons as well...valve relieved or not. Anyone know if there's a power/response difference?
  • Like 1
Suppose the big question is how much power do you want?
Found a new OEM crankshaft for $1200...LOT of money for any stock crankshaft IMO, but it's brand new and with new forged rods and pistons it should hold up well. There were some scratches in the bore of #5 and 6 that I could hang my fingernail on so I'm going to order 87mm pistons for it. I put the extra "stroker money" towards a Tomei oil pump and a new clutch (Exedy hyper single VF).
To answer your question this car will likely be able to push 400HP to the wheels pretty solid I would guess. If I'm not happy with that, the twin GT2860-7's will be coming off and a single will go on.
Still debating which ECU to order.
Also debating valve springs...are they needed for Tomei Poncams B?
You will make more than 400hp on -7's with a new engine. Should see around 420. If you guys have E85 there do that and see 450
Don't go the type B's and no valve springs are not needed. Either get Type A or Type R (i would lean towards the type R)
The type B's will give a good lumpy idle but with the -7's you want more response. otherwise you may as well have gone -5's. I will be pulling my Type B's out and putting R's in at some point.
Good choice on the oil pump :yes:
As far as ECU goes Haltech.
  • Like 1
Go Pro Cams!!
Oil starvation can be a big problem on stock 26's, would definitely look at getting that addressed!
Lots of GTR's here from Perth Australia have tried and tested the HKS 2.8L with sweet results. All just about yielding 700hp and +.
One of my favourites..
http://antilag.com/forums/showthread.php?57975-The-new-COCHEE-2.8-GTR&highlight=cochee
Theres a LOAD of R32 GTR's being built at the moment here in Perth if you want any ideas of mod lists!
http://antilag.com/forums/showthread.php?56123-Jakes-93-R32-GTR
http://antilag.com/forums/showthread.php?58554-DITB-GTR-Build
http://antilag.com/forums/showthread.php?56177-R32-GTR-Blast-from-the-Past
http://antilag.com/forums/showthread.php?60172-Another-32-Datsun
http://antilag.com/forums/showthread.php?62198-1990-R32-GTR-Build.
Looking forward to updates. :)
Still going strong!
Did the busy work today. CLEANING and CLEANING oh and CLEANING.
Then got the bug to do something fun so I ported the manifolds at the turbo inlets. I also fix and retapped some broken bolts and then stoned the faces so I'll have a better sealing surface when it's time to go back together.
Had more time so I took a better look at the turbo outlet pipes (O2 senser housings) since I am still decided between the tomei set or not (WOW they are expensive!). I came to the conclusion that for -7 turbos that I have on the way that they are fine after a bit of porting. Actually the shape of them isn't bad at all, but the CASTING from the bottom to about halfway up is terribly jagged. There is also a step in the outlet so I basically smoothed that and then ran my grinder as deep as I could up inside the housings to knock off the casting roughness and then ran the sandpaper flap wheel to smooth it out more. I think for the small amount of time spent on these few things I will see big changes on the spoolup and power.
I also cut the TWIN TURBO pipe for the slip-in divider. I need to hit the hardware store tomorrow to get some aluminum, but I'll bring this and the oil pan (Greddy sump on the way) to get welded up soon enough.
Next will be porting the heads (mild cleanup only), and lapping valves...I will check the valve guides while I'm at it.
Also tomorrow sometime I'll make a detailed list of what parts I plan to put on the car.
Patrick
Well we are taking a step back now...
Good thing I didn't order the pistons and rods that I was literally about to click BUY NOW on. The Nissan crankshafts are apparently on some intergalactic backorder and lots of people have been waiting on them for quite some time. I was notified that my order was backordered so I'm going back to the idea of going stroker and have decided on the BC 2.9L kit with the 79mm stroke. I am decided on the "sportsman" rods in this package as the only difference between them and the +625 rods are the fasteners (I talked to the BC tech about it). He said the sportsman rods would be very good likely up to 900-1000 HP depending on revs and that the 625 rods should be used after that.
I'm wondering which pistons (CP or JE) and CR to get as there are many options offered for both. I like to err on the side of more compression (9.0:1 max) as it makes for a more fun streetcar, but this one is already going to be stroked so maybe this won't be required...Maybe I'll just spec the stock 8.5:1
Despite the oiling and seriously strong rotating assembly I think I'd still like to set target revs around stock (7,800?) for insurance purposes. Looks like the build is going to be a bit more power anyway now so those -7 turbos might not be on there very long :)
Patrick
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
