Building this thing from a rolling shell into a dedicated drag car build.
- 3.4L Spool stroker kit with drag I-beams
- TH400 3-speed auto
- Mickey Thompson ET Pro Radial tyres (275/60/15)
- Goal is 7.xx seconds @ 175-ish.
https://www.sau.com.au/forums/topic/448268-275-radial-r33-drag-build/
Holy Shit, that car reminds me of buster!
Funny that! :)
Bought valves, springs, locks, retainers, guides and seals today. Got a great deal from Fabre on the lot and it was all in stock.
Head being disassembled tomorrow and the block arrives tomorrow to begin prep too.
Edited by 2rismo
Very cool.
Do you have an approx completion date?
ASAP. I've dragged my feet with other pursuits in the time I've had it. It's all systems go now. I'd like to race at Sydney Jambo in March with testing prior.
Precision Gen-2 8891 and 66mm gate:
Enough assembly lube for 8 RBs:
Dirty, dirty diesel:
This is unnaturally attractive:
Almost all of this is staying out. Anyone need any airbag stuff?
All caged up:
Lots left to do:
  • Like 1
I'm curious to see the machine work required to fit the RB head.
Any reason you are going the TH400 over a lighter option?
Will be sweet to see this car ripping huge skids again
I'll have photos of the entire process of adapting the head to the diesel block. Will also be machining up and fitting plugs for the head so there is no water near the deck at all. The block will also be filled to the deck.
TH400 was chosen because the power I expect this to make will be more than what my prefered trans will take (C4). The aftermarket support for TH400 is now so strong that they can be made unbreakable at this power level and application. They're just such a known quantity.
The street car ran 10s pretty easy and needed a cage, GTR rear end, different suspension etc. It has since had 30psi jammed into it and it made 415kW. It will run 9s soon.
This car was offered to me as a roller with everything already done. As hard as it was to sell the red car, I have a history with this car too so it was an easy decision.
Kyle from 6Boost is making the exhaust manifold for this engine. Will fit a 5in dump without cutting up the bay and include the 6 x EGT bosses. Stoked.
Going for his 'pro-mod' manifold?
This should be amazing!
Out of curiosity what sort of rpm are you thinking of turning it to? I'm keen to know what sort of piston speeds people think are possible, especially with a 94mm stroke.
We currently turn ours to 8000rpm in our circuit car and that works out about 25m/s which is getting up there. Your engine being for drag purposes I suspect you are intending to turn it a little harder??
Edited by r33_racer
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
