Better fuel economy, because better torque.
You don't have to ring it's neck now.
On a road trip to Adelaide, I was getting the same economy as a 34gtt.
They said the motor had plenty of work on the Dyno and was driven around for a couple of days. The limiter was on and I drove it the same as usual on the way back, well not exactly, 5000rpm limit and no boost :)
Even without the final tune it was much better, especially on the twisty bush road were torque helps. I know blokes say it is only a gear change away (or 2 ), but
Totally different car to drive, I think I will get rid of the next 1000Klms very quickly and final tune done :)
Good news Pete glad to hear its sounding promising!!
So does the off boost driving satify you/compete with the TT VQ motor?
Yeah it seemed forever
I do not think it is as good as the TT350GT with the run in tune , 3.5 Lts, newer type motor and toss in a couple of turbos, different car, but after the tune, cams dialed in for response, with the limiter on 7500 - 8000rpm, I would put my money on the 34 :)
But the main difference for me is, I like to drive the R as the GT was an Auto and I got sick of no stick :cool:
I think I have to qualify what I have said as best I can :/
Both cars from idle ( no launch) to 4000rpms the 350 would beat the 34, the 34 has a motor that is has not had the final tune and I have no real idea what difference it will make to the response. But if the run in tune is a guide it should be pretty good.
The 34 with the final tune, approximate 100awkw extra with a bit more response, it would be interesting from idle.
Congrats on getting it back on the road
Thanks Daz
yeah good to be driving it again, now have to get the Klms done and tune it up and see what the sucker will do :)
  • Like 1
Should be done by Tuesday afternoon.
Chop chop!
Going to try for the Easter school holidays and stay a few days in Sydney.
If they can do it around that time we might be able to meet up after the tune and get your opinion on how it goes :/
They said most of the work needed was done on the Dyno , he said he likes about 1500Klms the motor before the final tune. Said to just drive it as normal but has set the limiter to 5000. Not sure how this works as they take it to 8000 on the Dyno.
They changed the oil after the run in, I have to keep an eye on the water and oil levels for a while, no problems after 400Klms :)
Took it for a run this morning, very smooth but needs the final tune to get more going on down there and lift the limiter out to 80000 :)
Did a few tests on low speed 60 in 6th, no problem anywhere and the same with all of the higher gears, I would say 2 gears better even with the run in tune.
It will be interesting to see what or any difference after the final tune to the low RPMs driving, I am sure it will be mad past 3500
that rev limit! :P
get off sau and drive it
Hi Dave, they said it was set at 5000rpm, I recon it kicks in at 4500rpm , so there is not much time as the turbo starts to work. It is not mad , just very linear from 0-100 ish
Piss off, went for 100klms before my daughter woke up this morning, no traffic , it was nice to drive this car now as is , after the final should be magic :)
I wouldn't expect much change to low revs power (below 3500) after the final tune realistically.
Glad to e proven wrong though
I also hope you are wrong and look forward to trying to prove it, lol
I was hoping for the thing to be spooled by 4000rpms after the tune. I was expecting it to be approximately a 800 to 1000rpms sooner than it was before the build using the same PT6262, but with the new OS Valves and the UE cams getting a bit more air in there , but that may be just wishful thinking :/
Good to see you have it back and hopefully I will get to see it when final tune is done, would be nice to compair side by side with my 3.0 34
It will improve a good amount when they start playing with cam timing, if there is something CRD do well its cam timing, I still use the settings they did on my 32 from 8 years ago and they should have learnt more since then
Dave was pointing out the rev limit is to be set to 80,000rpm :)
  • Like 1
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
