Duncan Posted July 3 Share Posted July 3 lol, that escalated. Perfectly reasonably though 1 1 Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002409 Share on other sites More sharing options...
CRSKmD Posted July 3 Author Share Posted July 3 3 minutes ago, Duncan said: lol, that escalated. Perfectly reasonably though perfectly reasonably for a daily driver for sure Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002410 Share on other sites More sharing options...
CRSKmD Posted July 14 Author Share Posted July 14 Just as a follow up on the Starlet before we return to our usual programming. Dyno check over. Runs rich but is safe. Makes 105.2kw/176.8Nm 141hp/130ft.lb on 11psi with the Stock ECU Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002680 Share on other sites More sharing options...
GTSBoy Posted July 14 Share Posted July 14 Oof. You're not wrong about "rich". I'm surprised not to have seen black smoke on the dyno. Less than 10 is fat enough, let alone diving below 8 at the top end! Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002682 Share on other sites More sharing options...
CRSKmD Posted July 14 Author Share Posted July 14 1 minute ago, GTSBoy said: Oof. You're not wrong about "rich". I'm surprised not to have seen black smoke on the dyno. Less than 10 is fat enough, let alone diving below 8 at the top end! First run had some woofs of black smoke then went away for this one I filmed. General driving i tend to see 10.2-11.5 on my gauge. Still gets 8L/100km. I should leave it alone and just drive it around but now i am considering a the 2 options of either FCD + RRFPR and see if a little more boost and some fiddling gets the AFRs more reasonable. Or option 2 looking out for a cheap Link ECU to wire in as standalone... Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002684 Share on other sites More sharing options...
MBS206 Posted July 14 Share Posted July 14 42 minutes ago, CRSKmD said: First run had some woofs of black smoke then went away for this one I filmed. General driving i tend to see 10.2-11.5 on my gauge. Still gets 8L/100km. I should leave it alone and just drive it around but now i am considering a the 2 options of either FCD + RRFPR and see if a little more boost and some fiddling gets the AFRs more reasonable. Or option 2 looking out for a cheap Link ECU to wire in as standalone... Put a link in. Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002685 Share on other sites More sharing options...
CRSKmD Posted July 14 Author Share Posted July 14 Of course a Link is the better option but $$$ which for what is meant to be “just a daily” might be overkill. Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002686 Share on other sites More sharing options...
Kinkstaah Posted July 14 Share Posted July 14 I'd make the argument that "Just a daily" is what needs the real engine management and real tune for it's driving around casual needs. You can cut corners when you DGAF for dailying or road use on a car. Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002687 Share on other sites More sharing options...
MBS206 Posted July 14 Share Posted July 14 I'm with Kinkstah. Good ECU so you can tune some of the shittiness out of it. Secondly, if you want cheap, look at something like Speeduino. Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002688 Share on other sites More sharing options...
CRSKmD Posted July 14 Author Share Posted July 14 2 Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002689 Share on other sites More sharing options...
GTSBoy Posted July 14 Share Posted July 14 Hell, even an old Microtech LT in piggyback just to run the fuelling would be a substantial improvement. You really only need to fix that one thing (which is bore washingly worrying). Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002690 Share on other sites More sharing options...
CRSKmD Posted July 14 Author Share Posted July 14 yeah i think i accept that something to address the AFRs are on the list for sure. Interesting how much different(richer) the dyno wideband (exhaust tip) reads than my one reads (pre cat). Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002691 Share on other sites More sharing options...
Kinkstaah Posted July 14 Share Posted July 14 10 minutes ago, CRSKmD said: Interesting how much different(richer) the dyno wideband (exhaust tip) reads than my one reads (pre cat). I just went through this on the dyno. - Only to realise most people consider the one in the sniffer on the dyno to run artificially/fake leaner by about half a point. We trusted the dyno readout. Dang. Most tuners tend to prefer the one closer to the header location, but also most dyno's will trust their own gear (obviously) and that gear usually involves a sniffer at the end of the exhaust as this is used on every vehicle. And if it reads 'incorrectly' it reads falsely lean which is safer than too lean. Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002692 Share on other sites More sharing options...
CRSKmD Posted July 14 Author Share Posted July 14 why would it be more accurate if its post cat and not where the wideband manuals tell you to mount it? Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002693 Share on other sites More sharing options...
Kinkstaah Posted July 14 Share Posted July 14 Supposedly because being (further) inside the pipe means it won't be affected as much by outside air. Mine is mounted roughly middle of the car, just after where my exhaust merges. No science there - Just where it fit and I wanted it after the merge of a V8. Most widebands request it be 1M from the exhaust port or thereabouts as a minimum. Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002694 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 14 Share Posted July 14 chuck this bad they/their into your car: https://www.kitsetperformance.com.au/product-page/microsquirt-ecu Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002695 Share on other sites More sharing options...
CRSKmD Posted July 14 Author Share Posted July 14 3 minutes ago, Kinkstaah said: 1M from the exhaust port or thereabouts as a minimum. 1 Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002696 Share on other sites More sharing options...
CRSKmD Posted July 14 Author Share Posted July 14 got bamboozled by the edited post haha "I just went through this, on the dyno only to realise most people consider the one in the exhaust pipe to be the more accurate one. My car is now tuned 0.3 rich. :p" 9 minutes ago, Kinkstaah said: I just went through this, on the dyno only to realise most people consider the one in the sniffer on the dyno reads artificially leaner. We trusted the dyno readout. Dang. Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002697 Share on other sites More sharing options...
CRSKmD Posted July 14 Author Share Posted July 14 My wideband which is post turbo, pre-cat reads leaner. Than the dyno one in tail pipe which is backwards to above. I guess its possible the dyno one or my one is out of calibration. Though mine is pretty new still... Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002698 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 14 Share Posted July 14 Post cat should read leaner vs. pre cat O2. Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/25/#findComment-8002699 Share on other sites More sharing options...
