Just as a follow up on the Starlet before we return to our usual programming. Dyno check over. Runs rich but is safe.
Makes 105.2kw/176.8Nm 141hp/130ft.lb on 11psi with the Stock ECU
1 minute ago, GTSBoy said:
Oof. You're not wrong about "rich". I'm surprised not to have seen black smoke on the dyno. Less than 10 is fat enough, let alone diving below 8 at the top end!
First run had some woofs of black smoke then went away for this one I filmed. General driving i tend to see 10.2-11.5 on my gauge.
Still gets 8L/100km.
I should leave it alone and just drive it around but now i am considering a the 2 options of either FCD + RRFPR and see if a little more boost and some fiddling gets the AFRs more reasonable. Or option 2 looking out for a cheap Link ECU to wire in as standalone...
Put a link in.
I'd make the argument that "Just a daily" is what needs the real engine management and real tune for it's driving around casual needs.
You can cut corners when you DGAF for dailying or road use on a car.
yeah i think i accept that something to address the AFRs are on the list for sure.
Interesting how much different(richer) the dyno wideband (exhaust tip) reads than my one reads (pre cat).
I just went through this on the dyno.  - Only to realise most people consider the one in the sniffer on the dyno to run artificially/fake leaner by about half a point.
We trusted the dyno readout. Dang.
Most tuners tend to prefer the one closer to the header location, but also most dyno's will trust their own gear (obviously) and that gear usually involves a sniffer at the end of the exhaust as this is used on every vehicle.
And if it reads 'incorrectly' it reads falsely lean which is safer than too lean.
Supposedly because being (further) inside the pipe means it won't be affected as much by outside air.
Mine is mounted roughly middle of the car, just after where my exhaust merges. No science there - Just where it fit and I wanted it after the merge of a V8. Most widebands request it be 1M from the exhaust port or thereabouts as a minimum.
got bamboozled by the edited post haha
"I just went through this, on the dyno only to realise most people consider the one in the exhaust pipe to be the more accurate one. My car is now tuned 0.3 rich. :p"
9 minutes ago, Kinkstaah said:
I just went through this, on the dyno only to realise most people consider the one in the sniffer on the dyno reads artificially leaner.
My wideband which is post turbo, pre-cat reads leaner. Than the dyno one in tail pipe which is backwards to above. I guess its possible the dyno one or my one is out of calibration. Though mine is pretty new still...
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
