SAU.NSW officially thanks Terry and Trish of Award Diff and Gearbox and Services for hosting this wonderful event
Topic: Vehicle Driveline - Clutch, Manual Gearbox, Transfer Case and Differential
Day/Date: Saturday 2nd May 2015
Time: From 10am to 1pm
Address: Unit 1, 18 Anvil Road Seven Hills NSW 2147
Google Maps URL: http://goo.gl/G21xmI
Parking: Some carpark parking and plenty of street parking available
Food and Drink: Lunch and drinks supplied
Cost is Free for Members - although non-members still have time to apply and pay
Limit of members who can attend is: 40
This tech event is going to be an information session about driveline components (clutch, gearbox, transfer case and differentials), common problems, driveline servicing/maintenance and an informal Q&A session.
One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general.
When attending one of Skylines Australia NSW events please try to:
* Be aware of surrounding environment and act accordingly.
* Drive courteously on the state’s roads as a true enthusiast should.
* Understand how important it is to maintain the good name of SAUNSW and thus, treat others accordingly.
* Any misbehaviour will not be tolerated and you will be asked to leave.
*** All advice and demonstrations given by workshops, professional practices and factories for SAU.NSW Tech Nights are the responsibility (of accuracy) of the establishments - not the car club.
*** Details may change. check back regularly.
Attendees:
1). GTRKat
2). Pete
3). MrFijiGold
4). BakemonoRicer
5). vorse
6). Clinton
7). Charles
8). Yo-Yo
9). r32-25t
10). Terry_GT-R34
11). Redline_GTR
12). levinboy
13). GTofuS-T
14). crashdown
15). Calsonic14U
16). Calsonic14U +1
17). Aggroman
18). sammi_d
19). Daleo
20). Aussie_Delivered_R32_GTR
21). e_Dog
22). Wongy
23). Kin
24). GoldZilla
25). PRO_32
26). MR33YO
27). ianjb
28). Aqua
29). Michael's R33
30). chriszila
31). nick_7g
32). CYBORG
33). WAGON_BOY
34). zebra
35). Jaeyon
36). Duncan
37). MrStabby
38). Bradley Frier
39). XKLABA
40). DekA
Reserves:
1).
I'm not having any luck with these tech days/nights!
Family birthday in qld I can't get out of unfortunately.
Have had work done by award (as have many other club members) and always found it of the highest quality and completely transparent in their dealings.
List updated
Weak
Same, I went to Award based on recommendations from the club members and was very happy with the experience.
Alex can I take your spot then? ;)
Of course you can :)
Will have to see if I have work.
I probably won't be able to make this.
Any chance of someone videoing?
Not sure Luke, will ask
  • Like 1
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
