i spoke to a custom garage today, he is doing some numbers and getting back to me,
he is extremely confident,
and has done things like this before, not the exact same, but swapping engines with jap turbo cars
What happened to your team of fabricators and cad skills?
wow you guys are really critical
have you ever heard of collaborating
you cannot do everything on your own
i have different guys making different things
all these components have to come from somewhere
gearbox adapter plate
custom CV chafts
custom tail shaft
custom exhaust
ECU wiring
throttle bodies
inter cooler piping
custom engine mounts
custom bonnet
fuel setup
custom panel beating the engine bay (big hammer)
you want me to make all that on my own, ill be here for the rest of my life
so i have found the best guys in each area to help me out
sorry if i spread the work around
my guys have certain skills, they cant do everything
now if i said i had a team of magicians, thats a different story
Wow, yes its going to be expensive, he said he didn't care about cost, if I had money to throw around I would get a Toyota 4 litre V8 in my 5 and then blow it, is that smart or stupid, who cares what other people think, I don't.
As for the RB, yes it was a good OLD motor, but by Christ there are better newer powerplants out there.
Stop posting, buy it and build it, post in here when its done.
As for the fab work, you need a pelethera of subject matter experts and fabricators for a project that involves lots of mechanical and electrical engineering.
Its been done before, its not new, just make it happen.
BTW, all this talk about street racing makes me think you are a pimply school kid, if this is indeed true, please go away now, thanks for the LOLS everyone.
Quoted for truth
Looks like it bump steers like a mofo! What's with the manual stick AND the tiptronic? Wierd....
Sounds like he's running 044's too....
Looks more painful than enjoyable that's for sure!
  • Like 1
looks like it runs an air shifted box of some sort...liberty maybe
Winner!
It is a drag car only, they have run mid 7's with an RB... now with a VR inside.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
