I've done a search and only found old info, so here it goes.
My alignment is way out and I need two new rears, so its time again to get that taken care of. Problem I have is that the previous places I've been to for alignments in the past are either monkeys who don't appear to know what they are doing / don't listen to me, the customer (Kmart, Bob Jane) or don't seem to have much experience in aligning adjustable suspension arms (strange, I know).
My R33 has coilovers, a/m sway bars at both ends and front and rear adjustable arms. I also know exactly how I want my car aligned (degrees, measurements, etc)
Where can you recommend, east side, that I can trust and knows how to deal with a car like mine?
Thanks all
Yep - Traction Tyres for me. Have used them on/off for 8 years. Just ensure you book ahead - they are very busy usually (a good sign IMO).
Once I got more serious I used Racepace for the GT-R, they set up their own cars depending on various factors but that's probably not down your alley.
  • 3 weeks later...
  • 8 months later...
Having had YET ANOTHER poor quality alignment I've come to the conclusion that I wont be trusting any more shops that make the bulk of their money from selling tires. Who would have thought such a straight forward process, that of aligning a car, could be f**ked up by so many shops. Whether its not understanding my cars adjustable suspension, poor service or simply setting it up wrong/inproperly I cant believe its been so hard to get this right over the past few years.
Ive since changed to a Pedders where the manager used to own an R33 and they seem to know all about suspension, as that's all they do. I think ill be going to a place like this, or perhaps a shop that sets up suspension for track/race cars in future as so many shops seem to simply not be able to do this properly.
Mmm, they stripped the camber bolt on my Evo then tried to tell me I need to bring new bolts every time I bring it in for an alignment. I had just tightened it myself so I knew the thread was fine. The mechanic threw his torque wrench at the wall when it stripped, I thought no wonder the thing is over torquing. lol.
Is it worth driving to Pedders South Melb? I swore I would never go back to a Pedders dealer but I have heard so much good press about that particular store.
The guys who operate Pedders South Melbourne aren't noobs, they are proper car enthusiasts in to modified cars. They had an R32 GTR track car and 180SX track+drift car. Ben spent a lot of time setting up my KW suspension to get the right camber setting, although he has returned to NZ now.
Here's their facebook page https://www.facebook.com/PEDSM/
The also fitted an electronic brake controller and HD tow bar on my X5, again top quality service.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
