No worries mate just ring him ahead of time and see what time suits as he is always extremely busy (which is a good sign!) I know he will be able to help you out :)
After this is over I need someone a bit closer that knows what he is doing :)
My mob is extremely busy :)
In theory these guys have to hand over a product that works correctly to a satisfactory standard otherwise they have to fix it at no charge, providing there is something actually wrong and in this case there is.
They sound like they are messing around and not being professional about it. If I had a customer traveling 350km to pick up a vehicle I'd ensure it works 100% before handing over the keys.
Secondly, get the password removed from the tune on the ECU if your warranty is only verbal as it won't count for squat unless it is in writing. If they claim intellectual property that is BS because there are plenty of reasons why it can't be.
Hopefully all gets resolved quickly and not at much more of your expense. Otherwise I'd be going further with it.
Edited by breaker1845
I have been in a few similar situations and if I do not get this sorted to my satisfaction it will go further and I know exactly what action I must take.
As much as I feel stuffed around I have to give them a chance to sort it out, they asked me to bring it in to them, so before I go all legal crazy I will give them a fair chance to fix it. Up until this build they have been very good, I guess this is what hurts the most. Being pissed around for over 5 months, it is now 7 months and still being stuffed around, it grinds you down after a while:(
I was busting to get my hands on the car and when I finally did, it was a heap of shit!
As for the ECU, it is mine and I paid for the tune that was done for my car . I have no IP agreement with them. I want it unlocked so if I want a totally new tune on the car at some time in the future, I can have it done. Who in there right mind would want to steal this tune, it was done for my car, using the bolt ons I have, what good would it be????????
Yeah as said above and maybe get some printouts from JEVS to put up so it can be looked at on here, id like to see what a good and poor tune looked like on a graph ;)
Edited by AngryRB
Ouch I hope they can sort it out.
I hope mines goes a little smoother
yeah, been a little messy, just hope it gets sorted so I can enjoy the car.
Distance is the killer with all of this :(
we are going to do a little long distance tuning, computer to computer to ECU program ,make some changes
Going to put the new plugs in, number the old ones and take some pics of each one for the tuner to look at, probably give him an idea if one or more are running differently to the others ?
Its more does the tuner know the ecu well, the cock head that blew my motor said he tuned plenty of Autronic's however seeing him tune he didn't know his was around at all.
Motor blew on the dyno whilst he was fcking around with the timing :( the whole time he never used a knock listening device
The tuner sent me an Apexi Power FC Hand Controller, we worked on Face Time and made some changes to get it working enough to get me to Sydney, thats why I said "sensitive little suckers", from my experience, not worrying about anything, just a comment :)
I like tuners who tune without afrs or you know winging it
what was the final outcome, $ wise :blink: did he man up ?
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
