I only run 15-16 daily/track and 19psi for dyno and drags, been doing it since 2002 and had replace a set cause bearing worn out and exhaust wheel was sitting on housing :D
Is that the SR VCT or VE ?
Doesn't the VE also do lift like the V-TEC
Had a remote tune this morning to see if they could get it a little leaner to stop the plugs fouling up and it seems to have more response in Boost off, low and higher boost levels. But still went tits up around 7000rpm.
But my question is, when I got my car back from the build the starter motor sounded like it was still engaged after I let the key go, screach! thought it was me at first , but not after that, after all the different cars I have started I should know when to let the key go :/
When I first told the builder about this they said maybe it should have had some lub on the shaft , then, it might be a mismatch with the new parts with the shaft ??
Now they said I need a new Hi Torque starter motor to go in, the old starter motor has no problem turning the motor over and starting the car, it just seems to stay engaged after it starts for a split second. I just want them to fix it as it was before the build?
Anyone had any experience with something like this ??????????
You wouldn't need a higher torque starter as the engine is now lower compression.
Not sure why they would have suggested that.
Lower compression, thought it was the same, maybe a little different with the lager capacity ?
Maybe because I suggested they did not install the starter motor properly after the build. It was OK before then ?
I love it when people say it was OK when we tried it , but the problems are there the first time you drive it out of the shop , farking black magic :merli:
Did you ring/email Jim to say that it still won't rev to 8000 RPM without it having a fit?
you cruel :( goes better to 6500rpm now and I challenge the whale for a quick run , TOMORROW! hehe
It is a minor hiccup that wont stop, hic hic hic hic hic , see what I mean, hic etc hic :)
Yes had a red , hic
Hi torque starter my arse, i have 9.5:1 static comp in my 3.0 with shorter duration cams then you and my stock starter starts it perfectly fine
mismatched parts is also BS, the flywheel starter ring should be exact to the original one and the starter motor gear will have a bit of wear giving more clearance then factory
It is most likely a sticky starter motor from sitting around for so long and should have been lubed before reassemble, but even then it was only 5 months, mine sat around for near 18 months and has never givin me an issue
  • Like 1
Hi Mick
This is what I mean, I might not know about modifying cars but I know if something is working OK and doing the job, you do not need to crank it up to do the same job, just fix it
https://youtu.be/ieVDfnUKN9s
this is what id expect from a big $$$$ build lol.. just throwing it up haha I know maybe totally irrelavent but hey the sound is enough to be ok with a bit less bottom end torque ...
start it up, run it and holy shit!!!
Edited by AngryRB
What Mick said.
Pete fwiw I wouldn't drive it other than to Sydney, you don't need it to foul up even worse when you're nearly there and in Sydney traffic.
he did a remote tune this morning and it is running much better, you can feel it, there is not much chance of making it worse,but?
Did you watch what he did to the tune?
Did he remove the password?
I am happy where my power is and it will only get better.
If you drove my car this morning and changed gears just before 7000rpm, you would have loved it, well I did :)
Once it is sorted it will be just what I wanted :)
Now that is some positive thinking,haha
Won't get worse, just considering the possibility of cumulative fouling. Probably not an issue at cruise but why take a chance when you might be spending a lot of time idling, stop start etc? Your call mate, just saying...
Damn that flutter!
look at the whole turbo to IC to intake plenum move from the 50psi!!
  • Like 1
Yeah, I know what you mean, but the idea of the remote tune was to tune it a bit more to the lean side to stop the fouling. and by the way it is running now I think he has done that, well I hope :)
He was happy with the result and has no trouble with me driving the car but I will not be doing much before it goes in for the retune
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
