I'm looking at a time factor and this car hasn't been running as a 3.2 all that long and cracks like that don't happen over night, maybe not at turbo change, that gets benefit of doubt but from stroker kit and retune for sure it was cracked, to what degree is the question
  • Like 1
Are you sure they didn't is what I'm saying? Who said the cracks were there when it was a 2.6?
Forget when it was a 2.6, maybe thats when it started to pack up ?
It has only been a 3.2 for a blink and it has been stuffed from the first time I drove it hard ish, the next morning after the final tune. I ran it in over 2000klms.
I would think that the holes and cracks could have contributed to the problems with the tune, something was making it difficult to tune it properly , just guessing as I have no idea what a stuffed manifold would do, I have never had one on a car of mine.
I guess the final tune will give us an idea, maybe it was a combination of factors?
But I think it will be a good result :cheers:
Agree to disagree. They look very fresh. No carbon build up on some of those probably indicate less than 100km of driving
This is a pic of the inside of the manifold, tell me what's missing or are you saying this is a fresh manifold ?
Or did you not think Jez would clean the manifold to see the cracks better
  • Like 2
This is probably when it cracked because it's the first time it really saw the extremes. On the dyno temps are pretty well controlled and the manifold doesn't have the stresses exerted on it like those seen on the road.
No big deal just change the mani and hope that everything else is in order.
That sounds good but in theory about first time extreme driving BUT when I got it back it was limited to 5000rpm, put about 2000klm on it, took it back for the final tune, the next day when I took it for a run while I was still in Sydney it would not go over 6000rpm without coughing and farting, phoned them and they said bring it back on Monday, so I booked in for a couple more days. Had the re tune and drove home.
Next day I had a chance to see how it went, it would not go over 6000rpm without coughing and farting, told them,put another set of plugs in , 2nd set, he did a remote tune but the next time I tried to drive it hard, same shit and waited 3 months, back in, 1 month later got it back.
If you saw the Dyno, the psi dropped from 23 to 18.5 from 4500rpm to 7000rpm. I could feel it , Mick could feel it. But it was not farting anymore at 6000rpm,
So there was no way it had EXTREME anything as it was only up to 8000rpm once when Mick drove it to test it out. It was taken to 8000rpm MANY times on the Dyno with a fan blowing air to cool it, extreme?
I do not know why things are as they are, but they are. The builder was helpful all the way through this trouble but I cannot help thinking, when it came to really trying to find the problem they missed everything?
I know you're reverting back to your 1st suspicion of high manifold and turbine pressures but when Pete drops the next bombshell you can 100% eliminate your theory ;)
That and the fact the poor bugger has never been able to flog his car since he's had it to put it into any kind of extreme conditions as such :(
I said it is more controlled. Read what I typed.
I read u say rubbish to a comment about car getting hotter on the dyno than the road, im asking you to explain why??
Maybe u read what i typed
So im interested to know why, can u explain
  • Like 1
Its got nothing to do with the car getting hotter, its got to do with the stresses applied to the manifold through driving.
The environment is totally different.
The fact a dyno run only lasts for 10 secs max with the bonnet open and a blower on and everything being monitored with no other forces except for engine twist....
As opposed to an hour of relative extreme driving with interrupted air flow from traffic and lower speeds causing issues with under bonnet temps. Then you have bumps and forces and shock forces applied to the Mani from the turbo, waste gate, intake pipe and the movement of the dump and exhaust, together with the twisting of the engine. All these stresses while you have got hot steel under pressure that is probably not in the best condition will absolutely cause the Mani to crack and fatigue as opposed to relatively no forces on the dyno.
so taking that into account,
it's safe to say that the cracks formed after the initial tune from CRD that wasn't a good tune to begin with. Then problems with the tune started to escalate until Pete had enough and told CRD to stick it and decided to see Jez who had gone through a proper diagnosis checklist and found some problems and the cracks in the manifold?
Again, sorry to hear about your misfortune with this whole build Peter. One day very soon it will all be over and you'll be able to drive happily everyday.
  • Like 1
No problem Tom
On the positive side , have to wait until the 6boost mani comes in , installed and the tune done, I can assure you you will have a laugh at the end of this saga and shake your head at the final disclosure and will understand that there was another reason why I had so much trouble trying to get response from the time it was a 2.6 :)
I have copped some shit from a few blokes and most of it was/is very funny and I love it , keep it up :kiss:
No problem Tom
Why hold back if you already know why?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
