I will ask for a Vid but I wont be there, so ?
It is sort of like not going to the birth of your kids, well sort of, I hope it is not as messy, can you imagine all of those left over parts all over the floor, old manifold, injectors, nuts and bolts, you get the idea, but I am sure it will not be quite as good but second best is OK :banana:
You are a special guy!
Ok ok. I will review first.
haha, that will work, BUT can you be trusted :/
If the tune was done last I would have gone down, about 12 hours return, but it is having a pod cover made after the tune, I ask him to do it this way just in case he thinks the Turbo needed changing
  • Like 1
Hi Ben, just in case you misunderstood , I went to all of my kids births and could not be any prouder, wonderful experiences, but you can still joke about it :)
The dump pipe,, cooler and intake pipe are being fabricated, then he will welding the twin wastegate positions and then twin plumb back into the dump.
Toss it on the Dyno and if all of the problems have been fixed and worked in together he can do the pod cover, the END! well ???
  • Like 1
There's never "the end" but there comes the point where you have to say "enough"! Looking forward to the result.
Yeah Bob,but I "had enough" ages ago but as you know, if it is not right you have to keep going until it is.
After that and the car runs properly , it will be the end as there would be nothing else for me to do for a street car, good response and power , it already has great clutch, Front diff, trannie mods and a 2-Way LSD = HAPPY :)
II would expect to be able to post the Dyno next week and after I drive it home I will be able to say if it what I was after.
  • Like 2
Haha! The end....is there such a thing?
For me it's probably the gearbox;
1, R34 Getrag = money I have now
2, OS88 = money if I save up
3, R35 Transaxle = if I win Lotto this weekend!
haha, you are kidding Chris, you will never stop, a quick visit to a bank will get all of your dreams, maybe with note and a gun, LOL
Haha! I like your style Pete.... "Put all the money in the bag, my car needs a new gearbox!"
The 6 Boobs mani looks the biz.
Is that a single layer gasket sitting on there Pete......? Tell however speced that to stop being a cheap bastard and put a good multi layer one on like a Permaseal.
Edited by Sub Boy32
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
