I will ask, maybe it is the old one just sitting there, I do not think he would use a gasket that is not good enough for the job ?
Seen enough of them leak to not use them.
In a perfect world if the manifold flange and the turbo housing are dead flat then single layer one would be fine......but it is not always a perfect world.
I doubt he would something that would stuff the job to save a $ , that does not seem to be what he does , if he did use the gasket I would say it is dead flat :)
  • Like 1
The 6 Boobs mani looks the biz.
Is that a single layer gasket sitting on there Pete......? Tell however speced that to stop being a cheap bastard and put a good multi layer one on like a Permaseal.
He uses Silicone for the gasket
Almost like he has done one or two before
Spot on, guess it is that RTV Silicone :)
He is going slowly through my car and sorting out what he thinks will get the best results and I cannot wait to see / feel the difference the changes make.
People around here are acting like Jez is a noob.
Such noobs
Once he told me he was using Silicone I had to Google it, I did not know they had a Silicone that could handle that much heat, so learnt a little more today :)
So manifold is in and looking pretty.
Turbo going on?
Turn the wick up yet?
Should be on the Dyno very soon
The wick up, I hope so , especially in the response zone, E85 and the boost controller should let me turn it up on demand :yes: But I cannot use the top end power now , well a little, unless I start going to Sydney and have some fun on track days for dummies :cheers:
"You cannot use the top end power"?
You can it just may get you into some trouble.
It is easy enough to get into enough trouble with an old VW :)
But these Rs can get you into BIGGER trouble :spank:
Edited by Nismo 3.2ish
Such noobs
I wouldn't know Jez from a bar of soap, but if he is using shit products like cheap single layer gaskets on a high end build like this I thought I would comment.
......sorry I thought this was a forum?
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
