Suspense, we need our next installment
So do I, it seems forever since I bought the heap and hopefully I will have a Dyno to post tonight or tomorrow, might get a few laughs with the final installment :/
But I might CRY :unsure:
But the test comes when I am driving it home :)
The new Pod set up is not as pretty as the original but if it works better, it will have a CAI when finished :)
Sorry to not go back through 95 pages to find the photo... Did they go from single to the dual pods or the other way around? I'm presuming the single is the new setup? Much neater in my opinion if it is. Less clutter = good times!
  • Like 1
Went single as the other setup did not work with the new 6boost setup
Already looks cleaner and will look cleaner again once inclosed plus no AFM to restrict flow
Tell Jez no rush, we still 5 pages to go :P
4 1/2 to go and I am doing my best to drag it out, hope I never get the car and make it to 101 :cheers:
As you see I am doing my best to get the magic 100 :anyone:
I look forward to your response on the cars response, and also Jez's response on the response.
Ben your response has forced me to respond to your response!
As far as Jez's response he has not responded with a response but I am expecting a response from him at any time, well if he has time for the response as he said he is busy and may not respond to my response to his earlier response that got mixed up in all of the other responses that people responded to.
I hope you receive this response in time to respond to my response to your earlier response .
If you have time to respond I look forward to your response :cheers:
Fark this life is too short to respond, I think I will have a red and send you my response later on
  • Like 2
The new intake looks really nice and neat pete :yes:
Got used of the shinny intakes and pods and black tossed me at first, but it will have a pod cover anyway and I think it is a better position, so all good :)
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
