If you have time i would source a kit from the UK. Its the only place that seems to make the heater hoses for gtst (in silicone hose) think i ordered these from boost junkie or something along those lines
The rest of my hoses are JJR im fairly certain. Its silicone hose, works fine
Oem doesn't leak tho, which if you're happy to have to retighten all the clamps every so often to fix the leaks then yes it worth saving the $350, I am a do it once kind of person
This is from personal experience on my own car
  • Like 1
But Cal don't you have a 25, not a 26.
Under the plenum on a 26 is horrendous and you don't want to have to go back to re-tighten anything. (not that you could anyway)
Apart from the coolant hoses, there's the vacuum ones as well.
Stole this pic of a silicone hose install and below that mess are the water/oil cooler hoses.
I bought the Autobahn88 silicone hose set, fitted the easy one across the front of the cam belt and it pushed straight off, diameter just not right.
So that set went in the shed until I can afford OEM.
$350 sounds crazy cheap for OEM though???
Ahha i knew there were more hoses but didnt quite realise there were that many more haha. I thought mine was bad even with 1/3 of them deleted.
Lets put it this way. If you buy shit quality hose you'll be doing it again once they split or fall off, lol.
I presume the JJR is okay but the best would be OEM. If you calculate the efforts spent on removing the plenum again to do the job again if the kit fails you'll see why it's worth it.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
