I can't quite remember where I saw the photo but I do remember seeing rb26 covers painted in wrinkle paint. Very similar purple & it looked hot!
How do you find those clamps on the justjap intercooler silicon joints?
I have a few ideas but at the moment I've got traction issues and with an extra 25kw it's just going to be worse, so at the moment my main focus is going to be improving that.
I did the bolt into back of transfer case mod to my 32 cause the 4WD drive was near none existent, the difference is unbelievable, no more tail happy fun times :/
The lsd in my car doesn't work at all and the attesa pump has to keep priming even while standing still. So I'm going to replace a few of the consumables in the awd system which should fix most of the issues
Lol nice, I might have a chat them instead of buying a new center just hope they can do something not quite as aggressive as that tho
I check the actuator system every so often for air and nothing comes out so I think I'm pretty safe there
I have recently changed how I bleed the 4WD to cause the way the manual says to do it doesn't get all the air out :(
I got Award to rebuild a spare 32 diff I had which is now in the 34 and it is now almost like a locker lol
I can confirm. Once warm it was carrying on like my Nismo 1.5 way.
What's your new bleeding method mick?
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
