The more I looked at my ac condenser the more I noticed how bad of shape is really was, so as much as it killed me to pay the asking price I bought a new one
and here it is fitted to the car and also I painted the fan and bought a brand new receiver dryer as well
  • Like 4
Looks purdy
You'll be glad you did replace it when it's all buttoned up
Whislt most wouldn't be able to notice a old busted arse condenser and dryer, you would have been jaded if you didn't change it when you had such easy access
  • Like 1
On 30/10/2021 at 10:55 AM, r32-25t said:
Thanks mate, every time I think “do I really want to?” I end up just saying if I don’t do it now I’ll never do it
Fk yeah, horny looking now.
  • Like 1
So far every time I haven't just bought the part while it was available I've regretted it. I swear everyone and their mother is hoarding parts like they plan on scalping them in a year or two.
You can thank the USA for f**king that up for everyone, before they were allowed to have them these cars and their parts were cheap and plentiful.
  • Like 1
  • 4 weeks later...
On 8/12/21 at 8:17 AM, iruvyouskyrine said:
Who did your elctroplating on the bolts and how much did it cost? Looks like it was worth it unless its stupid expensive
Elite plating in smithfield, was $150 for every nut, bolt and washer in the bay and on the engine, also did the bonnet prop and latch and a few brackets
What colour did you do the Bonnet stay?
not sure what to do with mine
I did it in the olive which is the original colour, if I could go back I would have just done the whole lot in gold
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
