Boss left today for a 2 week holiday, then a 4 week working trip visiting distributors around the world...
HR is on a call as we speak to an agency, either to replace me or to get on board in case I do run out the door (even though I've said that I'm not going to) or to get me an assistant to reduce this workload.
Spoke to one of the girls in Accounts about the whole thing and she says that she's seen nothing to indicate I'm about to get let go. She's the one I leaked info to, knowing that she'd tell people... So was very careful in my wording about the whole thing.
We'll see over the next few days I guess... in the meantime, I'm banging out as many tasks as possible and helping out everyone in the office, to counteract the possibility of others planting the seeds of disloyalty...
Unrelated, going out to Bells Hot Chicken for dins with some track day mates. Should be a good time.
ouch no good.
He must think you are easily replaceable hence getting HR to start the process.
The assistant sounds like a trap, probably there to absorb the information before you bounce.
Considering that hiring the assistant could have been a pay-rise for yourself... (and probably cheaper in the long-run as well)
what the actual f**k is going on there?
Bloke pulled a butt muscle, dry ice gun to insta-cool the area and reduce damage / speed up healing I believe... saw a bit about it on the news or the project or something the other night.
ouch no good.
I say he's still bluffing for an answer - play hard ball til the end Simon - he's pulling out all the stop cards until you budge
mr-thomassoulo-the-butter-shave-seinfeld
So in other words...butthurt
also, hopefully all the butthurt today disappears. VWL gets too much somedays.
Sounds like you sure showed him!
  • Like 3
come work for me.
  • Like 1
Wu-tang!
Need to find some CBR pencil coils for the SR, then only need an autronic CDI and a small wiring mod. Coil on plug into the sunset.
(I should have done all of this month's ago. Determination and motivation has been low until things started happening)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
