Have a VoIP Provider who cut off our ability to make International Calls from our office on the 23rd of August. I've been contacting them for 3 weeks to try and get this shiz resolved... keep getting told that the director of the company is going to call me back within 10 minutes etc... Nothing.... Multiply by over 40 phone calls (30 of which just ring out (To their Sales / Support / Accounting departments).
Getting real tired of this...
are you one of those people with a carry-on bag the size of Andre The Giant's torso?
I usually take a back-pack and a laptop case and combined theyre the smallest items on the plane (in overhead compartment).
well it a qantas approved roll on and if I'm flying other than economy and it iternational yes as I get my own locker.
if economy I have a soft bag that I can fit around others bags.
so from what your saying your the one breaking the rules as you can only have ONE carry on bag.....
As a silver member I reserve the right to take more carry on than you
I think
that's the one area status does not help, carry on limit same for all classes/status.
check in however.
using the Qantas first Class check in, you arrive at the door a bell hop with a luggage trolley picked up your luggage from your and wisks it away and no scales.
considering the luggage limit is over 100kg, they figure if you can carry it in your probally under the limit.
which reminds me better check the winter menu to see what wines are on the list for next week
http://www.ausbt.com.au/files/Qantas%20First%20Lounge%20Winter%202015%20breakfast%20menu.pdf
this is true. but its handy because i can put them into different nooks and crannies left by other bags. Whilst others trawl the length of the plane looking for somewhere to fit their poker set briefcase.
on that note, i hate queues and often wait until the last minute to get on board. often a bad move, but not special enough to get priority boarding.
My last trip with Jet* they placed a bag scale at the queue with dedicated staff to weigh all carry-on.
Doesn't make things easier when you have to carry steel-cap boots & a work laptop
yeah and I think they dropped the kg as well at same time.
last time I traveled with them...1.5kg, was not travel for work, spare change of beach clothes and a tablet. (no lounge so was not worried about attire.)
I've had that.
in the Philippines when we went to Boracay it was a prop job.
they weigh every bag and every passenger to get the weight distrubution correct.
flight was half full and there were 2 gents and the front sitting side by side with the rest of the row empty
other dude went to move to the free seat and stewardess shouts at them to sit back.
last time I caught a prop job.
Nothing worst than someone taking up your side of the overhead storage!
Usually all the asian that line up at the front of the queue and bring in bags each ruining the storage system for the whole plane.
Just like people in cinemas who never sit in their allocated seat
I wish somebody could explain why they don't load the plane passengers from the back first like it makes no sense you can't get to ya seat cos the jerks are loading over head lockers in rows in front of you like wtf it's surely a smarter system?
/endrant
as the ppl at the front of the plane are more important.
or as per one of my biggest hates, those that are at the back start walking down and put their bag in the first gap filling the front rows.
most larger planes do call it buy block of rows for that exact reason, but that would require ppl to be at gate on time and to do what told, which seems impossible for most travellers.
  • Like 2
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
