Barry believes it, with E85. RB26s with 98 make about 340-350 with GT-SS.
Im not sure of the state of the car itself, but fair level of supporting mods to get it up to 400 i thought. Solid fuel pump setup, big exhaust (and all the GTR conspiracies that come with twins), clutch... Im sure there is other stuff i havent thought of.
i'm just going to throw it out there... but has anyone considered that the RP dyno might just read lower than others?
(not that it matters in any case)
It's all marketing...
- make the dyno read low where people have money to spend for more upgrades
- make the dyno read high where people are a one-time show so they can advertise & bring in more business
illuminati
Yes but not nearly as fun as paying out hub dyno people for thinking they have more power than they do
  • Like 1
I can't see there being an issue with it hitting 400 on e85... it would be absolute max but should be possible
Yeah either way I don't really care about the top end power figure; never have. Within reason (obviously I'll be shitty if it finishes up at 250), but it's the midrange and linear torque I want here. I judge this by acceleration and seat of the pants alone.
Will never forget the '450rwkw supra' on e85 at the chasers dyno day rocking up with skinny 17s on the back did a bout 10 runs to try and beat the 2 falcons :P
Yeah the falcon 4l turbos are quicker than the 5l v8s (at same or similar power) because of the power curve pretty much constantly on their max power output whereas the v8s wind up. My power on a 6 pretty much runs 10s
Can't beat dat dere instant torque and response on the 8 doe
Whats eta on your gtr?
Edited by UNR33L
As soon as Barry gives me an ETA I'll multiply it by 2-3 and let you know
Waiting for some parts at the moment apparently
Doing some oil supply bulletproofing
Only has to be 50% of value for write off I thought? 2k excess sucks but that's nothing compared to what i'd get paid out if needed
Daily driver but I think on policy is only 10,000km a year
Edited by UNR33L
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
